Activity Forums DaVinci Resolve Proxy media missing size & ratio attributes
  • Proxy media missing size & ratio attributes
    Posted by Joanie Menard on April 29, 2022 at 9:55 pm
    Hi
    I created half resolution Proxy media in ProRes 422LT of my original 5028×4152 DPX source media. This is material meant to be de-squeezed into 2.40 widescreen letterboxed into 3840×2160.
    When I turn on “Use Proxy Media if Available” in the Playback drop-down menu, the switch to proxy works fine, but the proxy isn’t taking on all the attributes assigned to the source clip in the timeline.
    The color correction shows up on the proxy all right, but the pixel ratio and size do not conform to what’s been set for the source clip. The proxy stays “squeezed” and larger.
    The pixel aspect ratio of the clips are set to 2.0.
    The pixel aspect ratio of the timeline is set to square.
    This set-up works great with the source material, but not the proxies.
    It’s as if the metadata that tells the online footage to show the footage 2:1 doesn’t seem to flow through to the proxies.
    This is on Resolve 17.4.5
    I’ve tried changing the timeline to cinemascope, the clips to square, un-linking re-relinking the proxies, conforming the timeline’s clips to the proxies using “loose name matching” and creating proxies at full resolution instead of half. Nothing seems to work.
    The issue occurs only with the Proxies method, the Optimized Media method translates all attributes without problem, but remains a 2nd choice solution since proxies are better for project sharing.
    Am I missing something obvious? Is this a confirmed software limitation and if so, has it been fixed in version 17.4.6 or 18? It seems that telling the proxies to adopt the same size and ratio as the source set in the timeline should be just as simple if not more than adopting its color calibration, which it already does.
    Thanks.
    Joanie Menard replied 4 years, 3 months ago 2 Members · 2 Replies
  • Michael Gissing
    May 2, 2022 at 6:30 am
    Assuming the aspect ratio of the proxys is identical, the proxys you created should follow. However what are your settings for Image Scaling. Under Input Scaling you have 4 choices. Scale to fit, center crop no resizing, scale to fit and stretch to fit. Try changing those settings to see if it is something to do with those settings.
  • Joanie Menard
    May 6, 2022 at 6:36 pm
    Thanks Michael. I hadn’t thought of that. Unfortunately I just tried all possible combinations (scale to fit, center crop, etc) in the Input Scalling options and none of them reproduces the same size/de-anamorphize attributes assigned to the source clip.
    As some have suggested, perhaps this might well be a loophole in the software re: proxies made from sources intended to be de-anamorphized.
    Color grading with squeezed proxies as a reference is still doable and I could settle for it and turn them on and off constantly to double check what I’m doing, but I’d also have to switch back and forth the Input Scalling setting to see the entire image because again, it’s not only the de-squeeze that’s not applying but the scale too.
