Activity Forums Apple Final Cut Pro Proxy files used in MultiCam?
  • Proxy files used in MultiCam?
    Posted by James Villeneuve on April 29, 2016 at 5:25 pm
    Hi ladies and gents.
    Quick question. I am doing a project with some go pro and Sony A7S footage. I converted everything to proxy files and things are running smoothly. When I create a multicam clip, the background processes rev up and FCPX is transcoding the files in the Multicam.
    So my question(s) is(are)… Why doesn’t the multicam shot I created simply use the proxy files that I generated? Is this a setting I’m unaware of?
    Is optimized multicam footage different from proxy files? Wha?
    Thanks in advance!
    James.
    Robin S. kurz replied 10 years, 4 months ago 2 Members · 1 Reply
  • Robin S. kurz
    April 29, 2016 at 5:46 pm
    One can only assume that it’s transcoding as per the default preference setting:
    Whether you’re currently in proxy mode or not, with the default setting it will/should transcode for when you’re in ORIGINAL mode either way.
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
