Activity › Forums › Panasonic Cameras › Proxy files on 2700 VariCam
Posted by Phil Yunker on December 9, 2011 at 4:56 amCan one record proxy files to a SD card on the 2700? is there a additional board needed for this?
or is the only way to record proxy files is to use the Panasonic AJ-YAX800G P2 Proxy File Encoder Card?
On page 140 of the manual it talks a little about the use of SD cards and proxy’s but does not go into enough detail.
Any help would be appreciated.thanks.
PHIL
PHIL YUNKER
Vanguard Media & Entertainment
http://www.philyunker.com
http://www.linkedin.com/in/philyunkerHelmut Kobler replied 14 years, 8 months ago 4 Members · 12 Replies -
Brian Young
December 11, 2011 at 6:48 pmHi Phil,
Yes – you can record proxies to an SD card on the 2700 but yes – you do need the Proxy File Encoder Card in order to do it.The card fits in the “hump” to the rear of the handle – just in front of the wireless slot.
When installed, it allows you to record proxies on: the P2 Card OR the P2 Card AND the SD card. I do wish you could record them to just the SD card, but that’s not the case. You also have 3 choices of recording resolution and with/without timecode window. (1.5 Mbps, 768 kbps and 196 kbps)
you can download the manual for the card here:
https://www.panasonic.ru/upload/iblock/c38/AJ-YAX800.pdfBrian Young
Los Angeles
http://www.FlacaProductions.com -
Phil Yunker
December 12, 2011 at 5:18 pmBrian,
Thanks for the info. Guess I’ll have to invest in a proxy card.
Thanks again for the help.PHIL
PHIL YUNKER
http://www.linkedin.com/in/philyunker -
Matthew Romanis
December 12, 2011 at 11:05 pmThe thing to be aware of with this Proxy card is that there is no embedded time code that matches back to the main clips, only burn in time code. Each clip starts at 00:00:00:00.
I found an elaborate work around in final cut to get the offline process going, but it is very clumsy. If you have the time, something like Proxy Mill is easier to work with in a complete edit sense. -
Phil Yunker
December 12, 2011 at 11:11 pmMatthew, thanks for the info. that is a very important info for me. seems like the time code would match, almost defeats the purpose of the proxies if the TC doesn’t match the master clips.
thanks!
PHIL
PHIL YUNKER
Matthew Romanis
December 12, 2011 at 11:35 pmYeah, that’s what I thought when I got the card. When we bought it we had to commit sight unseen, and then couldn’t believe that it was engineered that way with no firmware upgrade possible to remedy the problem.
The Dark Side kicks P2’s rear end all over town in this area. -
Phil Yunker
December 12, 2011 at 11:45 pmDoes Panasonic know this is a short coming?! Guess I will go with proxy mill and save a thousand dollars or so. THANKS!
“Dark Side”? oh do you mean the “S” word?!
Thanks.
PHIL
PHIL YUNKER
Matthew Romanis
December 13, 2011 at 12:04 amShhh, can’t say that here……
I jest.
It’s unfortunate that this is the case.
My HPX 3000 would be fantastic rather than just great if there was embedded timecode based proxy support. -
Phil Yunker
December 13, 2011 at 2:41 amWell, I think the 3000 and the entire line of Professional Panasonic cameras are fantastic primarily due to the recording CODEC.
I have been testing the demo of Proxy Mill, do you find that the burned in time code of the proxy does not match the master clip perfectly?
PHIL
PHIL YUNKER
Matthew Romanis
December 13, 2011 at 6:02 amTo be honest, I don’t use it anymore (for various bug issues). I use compressor to H.264 after log and transfer to FCP to create proxies when I need them, which isn’t often any more. The individual clips have matching time code embedded, you just have to careful when re conforming as the H.264 files are a mix down of all 4 audio channels into 2, so there are some setting changes in sequence control to be aware of. Or you could just Transcode the P2 files minus ch 3+4 both for the offline and online.
I agree with you about the AVC Intra codec, and the look I can achieve from the HPX 3000. -
Phil Yunker
December 13, 2011 at 2:39 pmThanks again for the good info and the tips. This gives me something to think about, I’ll probably stick with compressor for proxy files for now. hopefully Imagine products (makers of proxy mill) will be able to work out the bugs and maybe Panasonic will be able to create TC matching proxies with their proxy card then I will take a look at these products again.
Thanks.PHIL
PHIL YUNKER
