Activity › Forums › Adobe Premiere Pro › Proxy editing
  • Proxy editing
    Posted by Eric on June 5, 2007 at 12:45 pm
    I was under the impression that Adobe Premiere Pro 2.0 had proxy editing capabilities. Strangely I cant seem to find ANY documentation on how I would convert my HD media into some form of a proxy version.
    Am I looking at having to purchase a 3rd party plugin in order to accomplish this, or am I missing something in my preferences?
    Marcus Van bavel replied 19 years, 3 months ago 4 Members · 4 Replies
  • Aanarav Sareen
    June 5, 2007 at 2:58 pm
    Premiere Pro does not have this feature.
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Steven L. gotz
    June 5, 2007 at 5:55 pm
    HDV file sizes are the same as DV so no real need to use proxies. Or, are you talking about a much higher data rate?
    Steven
    https://www.stevengotz.com
  • Eric
    June 6, 2007 at 1:00 pm
    I am working with uncompressed 720p HD video. Even with a pretty fast machine, I have to half size the video to make it run closer to realtime.
    This isn’t an instance where I can “Capture” lower quality video and then uprez later. What I have to work with IS the uncompressed stuff.
    Being able to work with a proxy of the full rez video would make things a lot more streamlined.
    Since premiere cant do this “normally” could anyone suggest another work around?
  • Marcus Van bavel
    June 6, 2007 at 2:37 pm
    You might look at Raylight which has a built-in proxy that works with Premiere.
    It would allow you to work with a full-res (high quality but compressed) 1920 x 1080 frame and a built-in proxy that is either 1/2 resolution (at full data rate) or 1/4 resolution at 1/5 data rate. The 1/5 data rate option, called Raylight Red, is lower than DV data rate so almost any media workstation can do it. Switching from the proxy to the full res version is a one-button operation. See https://dvfilm.com/raylight
