Activity › Forums › Adobe Premiere Pro › Proxy Edit in Premiere CS6 – Problems with unlinking and relinking media
  • Proxy Edit in Premiere CS6 – Problems with unlinking and relinking media
    Posted by Kelly Warman on September 11, 2017 at 2:23 pm
    I’m new to PP I’m working with PP CS6 on an iMac from 2011 in OS 10.12.6.
    I have downgraded 4K pro res files post colour correction from DaVinci Resolve to 720 res. files in Adobe Encoder to do an offline proxy edit in PP.
    I have finished my edit and I am trying to make the files ‘offline’ so I can relink them to the original 4K files (everything is named the same and in the same folder).
    When I select all on my timeline, under ‘project’ ‘make offline’ is greyed out, can someone please help me in explaining why this greyed out ? If I can’t make them offline then I can’t reconnect the 4K files.
    Your help would be most appreciated.
    Thank you,
    Kelly
    Kelly Warman replied 9 years ago 2 Members · 2 Replies
  • Matt Dunne
    September 11, 2017 at 5:33 pm
    Hi Kelly by any chance are the files you’re trying to make offline a multi clip? I don’t think that will work so try the same process with your media but in your project panel instead.
    Before you do any of this I would suggest duplicating your project as an “ONLINE” project because reconnecting to your full rez media might mess with your positioning keyframes and you’ll want to have a backup incase you need to trouble shoot anything.
    Hopefully this helps.
    -editor of things
  • Kelly Warman
    September 14, 2017 at 2:32 pm
    Hi, thank you for getting back to me. I’m not sure what you mean by ‘multi clip’ ?? Also where is the project panel. Sorry to be a total newb I’m used to FCP….
    Kelly
