Activity Forums Adobe After Effects proxies usless , main comp is fully rendered and not update
  • proxies usless , main comp is fully rendered and not update
    Posted by Hanna Dean on June 9, 2016 at 8:31 am
    so as i se them main comp is rendered in medium quality .mov file and when trying to change effects , add fx , remove current text , the main comp object etc wil not take effect. so its usless
    Walter Soyka replied 10 years, 2 months ago 2 Members · 1 Reply
  • Walter Soyka
    June 9, 2016 at 11:38 am
    It’s not supposed to update automatically. You’ve told After Effects to refer to a file instead of the live comp. The idea is to do this with something you are not changing to free up resources to work on something else in the comp. For example, you might proxy a background comp top focus your work on the foreground elements.
    You can disable the proxy in the project panel by clicking the little proxy rectangle to get your live comp back, and you can render a new proxy any time you like.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
