Activity Forums Adobe After Effects Proxies / Replacing Footage?? In CS3
  • Proxies / Replacing Footage?? In CS3
    Posted by Tony Gates on September 10, 2009 at 7:07 pm
    Question:
    I have a project that an artist created for me. I want to replace footage with new PSD assets, but I want the animation to match perfectly. What is my best course of action?
    Tony Gates
    Stuart Elith replied 17 years ago 2 Members · 2 Replies
  • Tony Gates
    September 10, 2009 at 7:19 pm
    In other words…
    Unlike Boris Red, where in a timeline of a composition I can go to the media icon and switch out a still image file for another still image file, I wanted to know if setting a proxy for a pre-comp or replacing footage is my best option.
    Tony Gates
  • Stuart Elith
    September 11, 2009 at 4:36 am
    I think there are a few ways to achieve what you want… I can’t see the problem with using Replace Footage in the Project window, like you mentioned.
    Otherwise, you can also select the layer you want to swap, hold alt and drag out the new item you want to use and drop it anywhere in the comp window. It will swap it over without getting rid of effects, keyframes etc.
