Activity Forums Adobe Premiere Pro Proxies do not automatically attach to original footage.
  • Proxies do not automatically attach to original footage.
    Posted by Asher Burridge on October 23, 2016 at 3:24 pm
    Hello.
    I am trying to attach proxies to my footage. I believe I have followed all the correct steps for them to attach with no problem.
    Im fairly new to the proxy workflow but have tried several things to rectify the problem. I have over 500 clips and to manually attach all of them would be a missive pain!
    The proxies currently sit on a separate drive to the location of original footage could this be the problem?
    Any help would be greatly appreciated.
    Asher.
    John Williams replied 5 years, 7 months ago 4 Members · 3 Replies
  • Peter Garaway
    October 24, 2016 at 9:50 pm
    Hi Asher,
    This info comes from Trent who worked on the Proxy feature. Hopefully some of this info will be useful if not, let me know and we can dive deeper into it.
    “Relink others automatically” has some conditions in order to work (which Create Proxies accounts for).
    – The Proxies must have names matching the Full Res/original with “_Proxy” appended to the name. e.g.: Full Res = scene01.mxf, Proxy = scene01_Proxy.mov.
    – The Proxies should also be in a separate folder, preferably next to the Full Res/original clips.
    – You then want to choose the first clip it asks to attach to and the others should automatically relink correctly.
    – Merged clips are not currently supported for Proxy
    That said, there still may be some cases where you will have to attach one by one.
    Some additional information on the Proxy workflows:
    https://helpx.adobe.com/premiere-pro/kb/ingest-proxy-workflow-premiere-pro-cc-2015.html
    https://www.youtube.com/watch?v=Y9EJjqVV41o
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
  • David Jakubovic
    April 21, 2017 at 1:46 am
    Hi there. Can I change the name of a clip in Premiere after I attached it to its proxy?
  • John Williams
    February 2, 2021 at 10:27 pm
    I may have missed something since this was first posted in 2016 but I have a similar issue with hundreds of Red raw files. As you may know Red spans its clips every 4G so can make multiple clips inside a folder depending on the length of the shot. It also uses a new folder for every shot – every time the camera record was switched off and on then there is a new folder – result: hundreds of confusingly named clips inside hundreds of confusingly named bins (obviously a system designed by a very clever idiot). I can live with that because importing them into premiere pro via the browser it only looks at automatically reconnect clips and treats them as one normal clip.
    But now the problem starts with proxies because when you tick ‘put proxies alongside original files’ when you generate the proxies it writes a set of proxies to each individual folder containing those spanned Red clips. So now you have hundreds of proxies each in hundreds of individual folders alongside their clips. These can only be attached one at a time – trying to do so as a batch usually causes the programme to crash and in any case it can’t do it.
    However, I went back to the drive and took out all the proxies and put them in one folder – tedious but not as tedious as relinking hundreds of proxies one at a time in PP. Once in one folder PP can find all the proxies as a batch and relinks (AKA ‘Attaches’) them.
    Maybe I should have ticked something else when making the proxies if I had known – written them all to one folder for automatic attachment? Maybe that will help you if you are doing proxies for Red and want to attach batches of hundreds.
