Activity › Forums › Adobe After Effects › Proxies – A tutorial or explination
Posted by Christopher Rotter on August 27, 2008 at 12:28 amHello, I still can’t grasp how to use Proxies does anyone have a tutorial or could explain to me how they work and how to use them ?
Christopher Rotter replied 18 years ago 4 Members · 6 Replies -
Roland R. kahlenberg
August 27, 2008 at 12:47 amIt’ll help if you had a specific question regarding proxies.
Here are a few notes on proxies –
1) Proxies allow you to work with a lower resolution media of the original, full resolution media
2) The proxy is a real file that is created. Select a footage item in the Project Panel and goto File>Create Proxy to create a proxy.
3) Ensure that your proxy file shares the exact same aspect ratio as your full resolution file.
4) You can also create a proxy of composition
5) Once a proxy is in place, you can switch between the proxy and the full resolution version by clicking on a square checkbow, to the left of the footage item
6) In the Render Settings dialog, ensure that the proxies settings for render are what you want. Occasionally, proxies are desired for preview renders and always the full resolution media is required for a final render.
Need more? Here’s Serge’s COW Tutorial on working with proxies – Using Post Render Actions to Pre-render elements and create proxies.
HTH
RoRKbroadcastGEMs.com – the leader in customizable royalty-free animated backdrops
Patrick Peterson
August 27, 2008 at 1:32 amProxies are basically a rendered low rez version of an object in your project. They allow you to work through your project quicker than you would. For example a large particle generated item take a long time to scrub through, but if you render out a proxy you could work through quick and easy.
Christopher Rotter
August 27, 2008 at 2:11 amThank You Ronald, I appreciate that advice was good and the link you gave was great.
Thank You
August 27, 2008 at 2:17 am[Christopher Rotter] “Thank You Ronald,”
No worries dude! I’ll remember to tell Ronald that when I meet him. 😉
Bestest
Mark Fogarty
August 27, 2008 at 12:21 pmYou might want to check out Andrew Kramer’s tutorial about proxies as well…
https://www.videocopilot.net/tutorials/proxies_and_workflow_tips/
