Activity › Forums › Adobe Premiere Pro › Proxie File question in Adobe Premire update
Posted by Bryce Douglass on June 21, 2016 at 11:32 pmHello,
I’m very excited about the Proxie files in the updated premiere version. I was curious about a few things.
1. Can I use Prelude and add metadeta and then import into premeire and create proxies without the metadeta going away? So far it goes away once I make proxies.
2. Is it true that AVCHD reduces quality everytime it renders? if so should I then be using the Proxie feature to switch to prelude Proxy to edit?
Bryce
Matt Dunne replied 9 years, 10 months ago 5 Members · 21 Replies -
Trent Happel
June 22, 2016 at 12:14 amIn 2015.3, Premiere does not currently support the metadata from the Proxy clip. It will only read metadata from the Full Res clip.
AVCHD is a compressed format, so yes, it will reduce quality each time you render/export. With the Proxy feature, the encoded Proxy is an attached clip, so you can still switch (Toggle Proxies) to your Full Res clip that has no quality loss.
Here is some more info on the Proxy workflow in 2015.3:
https://helpx.adobe.com/premiere-pro/using/proxy-workflow.html
https://blogs.adobe.com/creativecloud/now-live-the-latest-update-of-premiere-pro-cc/?scid=social62963616&adbid=1111251692251496&adbpl=fb&adbpr=341657335877606
https://helpx.adobe.com/premiere-pro/how-to/proxy-media.html?scid=social62964616&adbid=1111259035584095&adbpl=fb&adbpr=341657335877606Trent Happel
Adobe
Premiere Pro -
Bryce Douglass
June 22, 2016 at 12:32 amWell that’s interesting. I just imported a clip from prelude with metedata comments and it is still there after i make a proxy in premiere. The odd thing is the file isn’t changing. When I make a proxy I still see .MTS extension rather than .mov extension even when the Proxy is connected. Is that supposed to be the case?
Bryce
Trent Happel
June 22, 2016 at 1:28 amIf I read this correctly, it sounds like you imported the clip from Prelude and then created Proxy from that Prelude clip? If so, then the Prelude clip is your Full Res clip and metadata is kept from Full Res clips. Adding different metadata to the Proxy clip is not currently supported.
When you attach Proxy, Premiere will still continue to base the clip off of the Full Res. This includes keeping the Full Res clip name, extension, etc. The only two places you will currently see Proxy information is in Properties and the Info panel.
Trent Happel
Adobe
Premiere Pro -
Bryce Douglass
June 22, 2016 at 2:50 amIs it possible to even use after effects at all if I have made a proxy file in Premiere?
Bryce
Matt Dunne
June 22, 2016 at 2:38 pmI was just reading about this and it says that the proxy workflow isn’t compatible with After Effects so you can’t dynamic link. Although I’m not sure why you would want to use a proxy that’s a smaller frame size than your original media. It seems like you would be setting yourself up for a headache.
I’ve been trying to wrap my head around the new proxy workflow but I don’t see the advantage of having the software handle it for you, maybe I’m missing something.
I can’t make full resolution frame sizes through the ingest function and when I attempted to create my own preset I didn’t see an option for codec/frame size. To avoid headaches I usually leave the frame size the same and just transcode to a lighter format.
It seems to me it’s easier to just continue making proxies through a transcode preset in Media Encoder or Resolve and then maybe use the “attach proxy” function to handle the switching back and forth.
Am I missing something?
Trent Happel
June 22, 2016 at 3:09 pmProxy allows for a number of workflows and transcoding via AME or other application to create Proxies, then use Attach Proxies in Premiere, is a valid workflow.
Create Proxies is another workflow to allow creation and automatic attachment of Proxy. To create a Proxy preset, you will first need to create an Encoding preset in AME (caveat is that you cannot use Match Source for Height/Width and Frame Rate – you can only set one of these parameters to Match Source. All other parameters can be set to Match Source). Then create an Ingest preset and in the Preset Settings, use your Encoding preset for the Format and Preset (in the ‘Transcode files to Destination’ section. In Premiere, click the Add Ingest Preset button in Ingest Settings or Create Proxies dialog and select your custom preset.
Trent Happel
Adobe
Premiere Pro -
Dan Geller
June 27, 2016 at 3:45 pmWhen doing as you suggest, the Create Proxies pulldown flips to Transcode. There appears to be a known issue with adding custom Ingest Presets created in AME to Premiere – it won’t permit using those Ingest Presets for Proxy Creation in the Ingest Dialog, only Transcoding.
Matt Dunne
June 27, 2016 at 4:03 pmI’ve experienced this as well. It seems crazy that I can’t create custom proxies. I don’t want to have low rez files when working with 4K just a lighter codec. If I’m working in a 1080p timeline and I use all that extra space to push around the image doing so on a clip that is 1024*540 is going to look terrible and when the client sees it I don’t want to have to explain why.
I guess I’ll continue using the online/offline process I’m used to until we can use this new feature with custom presets.
Trent Happel
June 27, 2016 at 6:46 pmThere is a known limitation for Ingest presets for Create Proxies. You cannot have the Frame Size (Width/Height) and Frame Rate both set to Match Source. You can only set one to Match Source if you want the preset to be compatible for Create Proxies. The other parameters (Field Order, Aspect) can all be set to Match Source for Create Proxies.
If you set Frame Size and Frame Rate both to Match Source, then the Ingest preset can only be used for Transcode in Ingest Settings (when you import the preset, it will automatically set to Transcode, as you have seen)
Trent Happel
Adobe
Premiere Pro -
Dan Geller
June 27, 2016 at 8:37 pmTrent,
Even deselecting the matches and creating alternative Frame Size or Frame Rate doesn’t help. I tried it and the app still flips to transcode.
