ProType Titler Question
Posted by Larry Brewer on November 12, 2007 at 3:26 amHow can I copy the attributes (font size, style, edge, etc) of a selected text block and paste it to another text block.
Larry Brewer replied 18 years, 10 months ago 2 Members · 2 Replies -
Craig Cooper
November 12, 2007 at 3:20 pmWhat I do is… (after I have created a Pro Titler effect)
In Vegas, use CTRL mouse drag your generated media left or right. Vegas asks if you want a copy or a reference. Just say copy. Then edit the generated media and change the text. So you should have the exact same text, font and effect in it.
Enjoy,
Craig -
Larry Brewer
November 12, 2007 at 5:05 pmThank you for the advice. I can use that method, that I wasn’t aware of, instead of the copy / paste method I have used previous.
But….. What I was really asking about concerned how to copy the font size, style, effects, etc., attributes of a text block WITHIN a graphic event, to another text block within the same graphic event.
And…. How do you get a thick drop shadow or even a wide edge around a font in ProType Titler. Glow and drop shadow don’t really seem to achieve the results I expected.
