Activity Forums Adobe After Effects Expressions Protected region – Independent timing?
  • Protected region – Independent timing?
    Posted by Darren Lee on May 2, 2021 at 7:29 pm
    Hi, I’ve a created a news ticker for use as a Motion Graphic Template in premiere. The text moves using simple expression:
    myx=position[0]+(time-inPoint)*-150;
    myy=position[1];
    [myx, myy];
    It sits inside a comp with protected regions for the in animation and out animation
    When testing, the speed of the text changes as the clip is extended or shortened.
    Is it possible to keep the text speed consistent regardless of its parent length? I had a look but there doesn’t seem to be an expression to target the parent comp duration
    Darren Lee replied 5 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
