Activity Forums VEGAS Pro Pros & Cons re editing on large TV
  • Pros & Cons re editing on large TV
    Posted by Paul Gregory on May 24, 2013 at 12:41 am
    I have a couple of questions about the possibility of using a LED or Plasma TV for editing. Why ask the question? Because you can get a considerably larger screen for the same amount of money & you have a TV inbuilt should you need it.
    I know that there is more concern if you are not using a dedicated monitor regarding color matching. Would you still have the ability with Vegas to also have a your old monitor attached as well for that purpose?
    Are there other considerations?
    Thanks in advance
    James Houghtaling replied 13 years, 3 months ago 2 Members · 1 Reply
  • James Houghtaling
    May 24, 2013 at 4:36 pm
    My son uses a 32″ flat panel TV as a main monitor and it works fine for browsing and watching online videos. However, I would think that the resolution limitations would be an issue while editing. Even though your final video may never exceed a 1080p equivalent, having the added resolution beyond that would make your editing easier. Not to mention you can pack a lot more pixel into a smaller size monitor than you would get out of a TV.
    My Hardware:
    Core i7 2.67GHz; Nvidia GTX580, 12 gig RAM Win7 64bit.
    My Software:
    Vegas Pro V11 with Boris Continuum Complete 8, VASST Ultimate S; Bluff Titler; AE5; PhotoPaint and other stuff.
