Activity › Forums › Apple Final Cut Pro Legacy › ProRess 444 Alpha channel?
  • ProRess 444 Alpha channel?
    Posted by Arnold Pistorius on September 11, 2009 at 1:33 pm
    Has any one Managed to get the 444 alpha channel to work?
    I am using After CS4 and when i Render out to the new 444 Proress codec you can export it with an alpha channel, however it seems to be ignoring the alpha?
    Ben Holmes replied 17 years ago 5 Members · 6 Replies
  • Walter Biscardi
    September 11, 2009 at 2:41 pm
    did you set the alpha correctly for the clip in Final Cut Pro?
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    Credits include multiple Emmy, Telly, Aurora and Peabody Awards.
    Owner, Biscardi Creative Media featuring HD Post
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Read my Blog!
    Twitter!
  • Rafael Amador
    September 11, 2009 at 2:42 pm
    I’m still in FC 6.0.5 s I have no Prores 444, but if is like any other codec you need to select a “Colors Millions+” option.
    rafael
    http://www.nagavideo.com
  • Arnold Pistorius
    September 11, 2009 at 2:56 pm
    It would seem the comp I was working off was broken, tried a Chroma sample and then did some basic matte shapes and exported it.
    This works better than Expected, a 444 Chroma keyed person in FCP running at real time. My only concern is its weirdness with gamma.
  • Jeremy Garchow
    September 11, 2009 at 3:55 pm
    [Arnold Pistorius] “I am using After CS4 and when i Render out to the new 444 Proress codec you can export it with an alpha channel, however it seems to be ignoring the alpha? “
    I had to trash QT and AE prefs for it to work. Once I did, it worked prefectly and in rt!!!!
    Jeremy
  • Jeremy Garchow
    September 11, 2009 at 4:43 pm
    [Arnold Pistorius] “This works better than Expected, a 444 Chroma keyed person in FCP running at real time. My only concern is its weirdness with gamma.
    In the output module of AE, make sure in the QT dialog you set the ‘gamma correction’ from Automatic to None.
    Jeremy
  • Ben Holmes
    September 11, 2009 at 7:24 pm
    ProRes 444 may be the best reason to use FCP7. Bye bye animation codec….
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
