  • Posted by Tel Jaba on February 28, 2009 at 11:28 am
    Hello everyone
    I am going to be working on my first HD project soon, And I’m preparing myself to that. the material that I am going to be working with is being shot of Sony EX 3 (HQ 1920×1080 25p)
    and I was wondering what would the workflow be after transfaring and importing the media into fCP?
    what is ProRes 422 and when and how do I do that?
    I would appreciate it if you could explain the ProRes to me in simple words!!
    many thanks in advance
    Tel Jaba replied 17 years, 6 months ago 4 Members · 5 Replies
  • Jerry Hofmann
    February 28, 2009 at 1:53 pm
    ProRes is a visually lossless codec you can transcode to using Sony’s plugin for XDCAM EX footage. It will look the same as the original, but it will render a ton faster at the cost of disk space. You can import the files using the Sony plugin, and choose them to be prores instead of the GOP structured media that is shot with that camera. It’s MPEG-2 in fact.
    You’ll need to go to Sony’s website, and in the support area for that camera to get these free applications, there’s a pdf or something too with them to show you how to set them up. There are two flavors of ProRes too… ProRes, and ProRes HQ. The HQ version should be used if your material has a lot of fast action in it, otherwise just use the other… file sizes are larger with the HQ version, but they won’t look much better than the standard version if there’s little or “normal” sorts of movement in the footage. (fast pans would look better for example in the HQ version, or fast movement like race cars etc…)
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Gary Adcock
    February 28, 2009 at 3:13 pm
    [tel jaba] “I would appreciate it if you could explain the ProRes to me in simple words!! “
    try starting with this thread on ProRes.
    https://forums.creativecow.net/thread/8/1024925
    “I am going to be working with is being shot of Sony EX 3 (HQ 1920×1080 25p) “
    Understand that for the EX cameras you will need the latest version of FCP (6.05)
    SxS driver and the XDcam Transfer tools/ FCP plugin.
    all of which can be found here.
    https://servicesplus.us.sony.biz/sony-software-model-PDZKP1.aspx
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Joe Procopio
    February 28, 2009 at 4:30 pm
    isn’t HQ 10bit and regular 8bit?
    Tel….also, if you are working in Prores…make sure your render settings are forced to Prores and not same as sequence…
    Broadway Video, NYC
    AVID/FCP editor/engineer
  • Gary Adcock
    February 28, 2009 at 5:36 pm
    [Joe Procopio] “isn’t HQ 10bit and regular 8bit? “
    No, that is incorrect.
    Both versions of ProRes are 10bit.
    gary adcock
    Studio37
  • Tel Jaba
    February 28, 2009 at 8:54 pm
    thank you so much for all your help
    I just found out that my producer was advised by apple that we work in SD which will be faster and take less space on hard disk and when we are done with the editing we can “upres” to HD by deleting all the media and reconnecting to the HD!!
    is that correct?
    what about color correction? is that done before or after the “upres”
    is the “upres” an easy thing to do?
    appreciate all your help
