Activity Forums Apple Final Cut Pro Legacy ProRes422 codec 4:4:4 chroma filtering
  • ProRes422 codec 4:4:4 chroma filtering
    Posted by Esky Ching on December 29, 2008 at 2:05 am
    There is an option to enable 4:4:4 chroma filtering, what does it do?? Generally will it brings better results ?
    Thank you.
    Rafael Amador replied 16 years ago 4 Members · 5 Replies
  • Rafael Amador
    December 29, 2008 at 9:44 am
    Hi Esky,
    When you digitize video to a “Chroma Downsampled’ format (420,411,..) basically you make blocks of four pixels and you record the Luminance information of each pixel. But the Chroma is averaged so you keep only one value for the four pixels.
    When you play or render the movie, this chroma is combined with the Luminance value of each pixels. This is what produce the “Blockiness” typical of the DV footage. The Chroma is applied in lineal fashion to all the four pixels.
    But if you apply a “Chroma Filtering” the Chroma is not applied in the same way to the four pixels. “Chroma Filtering” try to re-build the original Chroma as it was before down-sampling.
    It makes the DV footage looks definitively much better.
    When working with 422 footage you have two chroma samples for each four pixels block. You don’t have the blockiness of the DV so really no the same need for Chroma Filtering,
    When I work with ProRess, by default I let it OFF but is something that I still have to consider.
    Rafael
    http://www.nagavideo.com
  • Carlo Zoratti
    December 22, 2009 at 2:54 pm
    Thanks Rafael for the response and Esky to bring this up. I found this post very useful myself.
    Carlo
  • Elijah Lynn
    September 11, 2010 at 4:55 am
    Are there any stats on if this:
    1. Increases encoding time significantly
    2. Increases filesize
  • Rafael Amador
    September 11, 2010 at 9:03 am
    Hi Elijah,
    I don’t think that affects the compression time. I think that just add a kind of flag to force the Chroma Filtering on playing.
    But that is just my theory. I have no info at all about how that really works.
    Rafael
  • Rafael Amador
    September 11, 2010 at 9:13 am
    Hi Elijah,
    Having a second look, I’m think I was wrong.
    The text has changed in the Prores compressor panel.
    I think before was “Enable 444 chroma filtering”.
    Now writes “Enable chroma filtering for 444 sources”.
    This must affects how the 444 stuff is down-sampled to 422.
    I think I wouldn’t check this button.
    Rafael
