Activity Forums Apple Final Cut Pro Legacy ProRes25fps to HDCamSR 24fps
  • ProRes25fps to HDCamSR 24fps
    Posted by Roland Denning on November 21, 2013 at 7:53 pm
    Can anyone help me?
    I need to transfer a ProRes 1080/25fps film to 24fps HDCamSR.
    The facility suggests I speed up the file by 4% and they will transfer to 24 and then pitch change the audio to compensate.
    Is this the best way of doing it?
    How would you recommend doing the 4% speed change?
    Many thanks in advance.
    Roland Denning replied 12 years, 10 months ago 4 Members · 5 Replies
  • Shane Ross
    November 21, 2013 at 8:24 pm
    Go to a post facility that has a TERRANEX or other standards converter box. That’s the best way, because timing will remain the same.
    The second best…is the method described, but the timing of the project will change as well.
    Shane
    Little Frog Post
  • Roland Denning
    November 22, 2013 at 11:24 am
    Thanks Shane –
    On the second method – if the orginal file is speeded up 4% then the 25fps is played out at 24, won’t the final timings remain the same?
    I’m in London, UK, and the facility seemed to think it was not worth using a standards convertor (they have a Snell Alchemist – Terranex are not so common here).
    Roland
  • Rafael Amador
    November 22, 2013 at 4:06 pm
    [Roland Denning] “On the second method – if the orginal file is speeded up 4% then the 25fps is played out at 24, won’t the final timings remain the same?”
    Yes, but Audio will speed up as well.
    Rafael
  • Nick Meyers
    November 23, 2013 at 6:52 am
    “The facility suggests I speed up the file by 4% and they will transfer to 24 and then pitch change the audio to compensate.
    Is this the best way of doing it?”
    i think there is slight confusion here.
    a common way to deal with this would be to change the playback rate of the clip.
    you can use CINEMA TOOLLS to do this “Conform”
    this will actually slow it down by 4%
    nick
  • Roland Denning
    November 23, 2013 at 8:29 am
    You are right, Nick. That facility I spoke to (who said speed up by 4%) didn’t really know what they were talking about. They really meant – reconform to 24fps resulting with a longer programme with lower pitch. A pitch change on a 5.1 audio track to me doesn’t seem a good idea.
    I have choice between Teranex or Alchemist. One facility (who had both machines) actually said the Teranex gave better results on this sort of conversion.
    Has anyone here compared the two?
