Activity Forums Apple Final Cut Pro Legacy Prores vs. ProresHQ
  • Prores vs. ProresHQ
    Posted by Tom on November 7, 2007 at 5:06 pm
    Is one 8-bit and one 10-bit? Or just different data rates?
    Been reading (seemingly) conflicting info on what bit rate they are…or maybe they can be either bit rate? Is there a place in after effects/FCP/Quicktime player that would tell me what bitrate I’ve encoded to (rendering out of AE and Compressor…)
    Besides 8/10 bit difference, any other diff between reg ProRes and HQ?
    Thanks all (and for you patience…) – trying to acheive the level of “guru-ness” (“guru-osity”??) I previously had with M100 with my new FCP system…going to take many painful posts, unfortunatley for ya’ll 🙂
    Tom
    Rafael Amador replied 18 years, 9 months ago 5 Members · 4 Replies
  • Paul Escandon
    November 7, 2007 at 5:12 pm
    Tom,
    Both flavors of ProRes 422 are 10-bit.
    I would point you to Apple’s ProRes422 white paper – it’s very informative. It’s here: https://images.apple.com/finalcutstudio/resources/white_papers/L342568A_ProRes_WP.pdf
    Hope this helps.
    Paul Escandon
    Producer | Director | Editor
    Apple Certified Trainer – Final Cut Pro
    Oremus Productions
    http://www.oremusproductions.com
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • Chris Borjis
    November 7, 2007 at 6:01 pm
    [mr.escandon] “Both flavors of ProRes 422 are 10-bit.”
    I’ve heard that as well, but what I don’t like seeing is that there is indeed an option for 8-bit prores in fcp.
    The HQ version takes up more disk space for sure, but I really can’t visually see a difference between it and the non HQ version. Still though I always use HQ to not take a chance as it takes up so little room compared to uncompressed.
  • Peter Dewit
    November 7, 2007 at 7:48 pm
    I think HQ is more intended for when you’re doing color correction or graphics work. The visual difference is pretty non-existent
  • Rafael Amador
    November 8, 2007 at 3:42 am
    What you get depends on how you set the rendering options: 8b or “high precision YUV”.
    Rafael
