Activity Forums Apple Final Cut Pro Legacy ProRes to H.264
  • ProRes to H.264
    Posted by Craig Johnson on April 6, 2011 at 12:01 am
    Haven’t found my exact answer. I like the way ProRes has ended up looking on my Blu Ray project burned in toast 10 using Compressor’s HD settings. All I’ve read points to a slightly better quality with H.264. I want to see for myself and compare so my question is: Can I simply use the ProRes timeline that I have already finished and send it to Compressor for H.264 encoding? I’m just using a iMac 27 quad core so rendering will be an overnight affair, just don’t want run the tongue out of my mac for the wrong reason.
    Craig Johnson replied 15 years, 5 months ago 2 Members · 2 Replies
  • Rafael Amador
    April 6, 2011 at 12:04 am
    [Craig Johnson] “Can I simply use the ProRes timeline that I have already finished and send it to Compressor for H.264 encoding? I”
    Yes. You can chose “Send to Compressor” and apply the preset you need.
    rafael
    http://www.nagavideo.com
  • Craig Johnson
    April 6, 2011 at 1:08 am
    Thanks Rafael….Seems like you are always helping me. It’s appreciated.
