Activity Forums Apple Final Cut Pro Legacy Prores to H.264 color shift
  • Prores to H.264 color shift
    Posted by Pradip Patil on November 15, 2011 at 9:08 am
    I am trying to export my Prores 422 file to H.264 encoded Mov or Mp4 file. But the files are slightly rich in reds. I have used compressor as well as Mpegstreamclip for conversion.
    This is happening first time to me. Herer is the screenshot with all the three files.
    What’s going wrong?
    Pradip Patil
    Mumbai,India
    Pradip Patil replied 14 years, 10 months ago 4 Members · 6 Replies
  • Thomas Morter-laing
    November 15, 2011 at 9:33 am
    I can’t remember the specifics of H364, but if I remember rightly its colour space is typically 4:2:0- its a pretty awful codec for retaining things like color accuracy. However there are ways of encoding to higher profile versions such as 4:2:2 but I cant remember them… :s
    Tom Morter-Laing
    Freelance Editor,
    Certified Apple Product Proffessional, 2010
    http://www.depictproductions.co.uk
    Sony Z5, with Rode NTG2.
    iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD.
  • Ross Daly
    November 15, 2011 at 2:35 pm
    Hello!
    Sadly, this is a known bug that has been around FOREVER. Here are some links that talk about it. The main consensus is that you can either shift the gamma before you compress it to offset the h264 shift, or there are some tweaks you can do to the converted file to make it appear correctly. Lastly, some people have had luck with the x264 codec. It is free.
    Good luck!
    https://byteful.com/blog/2010/07/how-to-fix-the-h264-gamma-brightness-bug-in-quicktime/
    https://forums.adobe.com/thread/769015
  • Pradip Patil
    November 15, 2011 at 3:40 pm
    Thanks for replys.
    I googled the issue and found a good piece of advice, thanks to shane ross. I was watching these files using quicktime player and that’s where the problem was. I installed quicktime 7 and the file made from H.264 preset in Compressor looks perfectly fine.
    Pradip Patil
    Mumbai,India
  • Pradip Patil
    November 15, 2011 at 3:42 pm
    [Pradip Patil] “I was watching these files using quicktime player”
    I meant QuickTime palyer 10.
    Pradip Patil
    Mumbai,India
  • David Roth weiss
    November 15, 2011 at 4:47 pm
    Even with QT 7 you will still notice a gamma shift Pradip. The gamma filter in Compressor will allow you to make slight compensation adjustments, just be sure to use it lightly as a little adjustment goes a long way. And, test it with short clips, as it may take you a few attempts to get exactly the setting you desire.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Don’t miss my new Creative Cow Podcast: Bringing “The Whale” to the Big Screen:
    https://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfitandSuzanneChisholm/1
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Pradip Patil
    November 15, 2011 at 6:06 pm
    Thanks for the info David. For the time being, our requirements are met. I will definitely try what you have said. This particular project has been an eye opener about the 5D world. 🙂
    Everything was so nice and easy till this project happened.
    Pradip Patil
    Mumbai,India
