Activity Forums Apple Final Cut Pro Legacy ProRes success on G5
  • ProRes success on G5
    Posted by Chris Paul on June 15, 2007 at 10:41 pm
    I am successfully capturing HDV to the ProRes422 codec on a G5. Here is my setup:
    G5 quad
    Rorke fiberchannel array
    JVC BR-HD50 HDV deck
    Blackmagic Multibridge Extreme
    Convergent Design HD-Connect MI.
    I am taking the HDMI output of the deck and converting it to SDI. The signal goes from HDV 720p30 to ProRes 720p59.94.
    I have captured from a number of tapes. The clips were anywhere from 2 seconds to 6 minutes in length. They are much sharper using the SDI input than the component analog input.
    I had presumed that the Multibridge did not convert to ProRes in hardware but perhaps it does. Either that or the G5 quad has more processing power that I thought.
    Anyway, I wanted to share this to show that ProRes can indeed be captured on a G5 right now.
    Chris Paul
    POV
    Stuart Ferreyra replied 19 years, 3 months ago 6 Members · 6 Replies
  • Shane Ross
    June 15, 2007 at 10:46 pm
    [Post Office Video] “I had presumed that the Multibridge did not convert to ProRes in hardware but perhaps it does. Either that or the G5 quad has more processing power that I thought.”
    Guessing the computer’s processor was faster than you thought. Because Decklink doesn’t have a hardware ProRes Converter. Only the I/O HD does, and it ain’t out yet.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Sean Oneil
    June 16, 2007 at 12:56 am
    Lots of people are reporting success capturing with a quad G5. That’s good news for those who have that.
    I’d like to know what it’s like using “Edit to Tape” with ProRes HQ HD.
    On my dual G5, I can capture ProRes SD no problem, but using “Edit to Tape” gives me a dropped frames error every 3-4 minutes or so.
    Sean
  • Sean O’connell
    June 16, 2007 at 1:27 am
    Has anyone tried capturing with pro res on a Mac Book Pro and then editing on a G5?
  • Chris Borjis
    June 16, 2007 at 4:13 am
    interesting post office.
    I have the exact same setup as you but i have a ciprico 4210 4gb fibre channel array.
    I captured 720P from my brhd50u via component and capture fails with dropped frames within 5 seconds.
    Running:
    G5 quad
    4gb ram
    multibridge extreme
    fcp6
    can you go through the steps start to finish for me?
    did you capture prores HQ or SQ?
    I would love it if my system could do that and now it sounds like it should.
  • Sean Oneil
    June 16, 2007 at 6:54 am
    720p60 is actually larger than 1080p24. But not by much.
    Sean
  • Stuart Ferreyra
    June 16, 2007 at 3:21 pm
    Great feedback!
    Stuart Ferreyra
    Timecode Multimedia
    Owner / Colorist
    Santa Monica, CA 90025
    https://www.timecodemultimedia.com
