Activity › Forums › Apple Final Cut Pro Legacy › ProRes renders and messes with framerate?
  • ProRes renders and messes with framerate?
    Posted by Alan Langdon on August 4, 2011 at 10:05 pm
    Macmini 2.4 GHZ 4Gb ram
    Final Cut 6.0.2
    I am editing a timeline that is 720p 23.98 fps. Apple ProRes (not HQ)
    The footage is in this same configuration, it was converted using Compressor from .mov h264 files.
    I made some animations in After Effects, rendering to the same codec and settings, using 16 bit color space. 720p 23.98 fps. Apple ProRes (not HQ)
    Stuff comes into the timeline perfectly, of course, no rendering needed. Mixes in with the footage no problem.
    But when I apply ANY effect to the footage or in a track above it (causing a need for rendering), what happens is the framerate gets messed up and I notice the animation flowing with a sort of “pull-down” , so some frames are repeated…! The motion of course looks jumpy in this case, so I decided to post this question to find out why this is happening.
    I am rendering the timeline using the same codec as sequence, full frame-rate and resolution, choosing to render all 10-bit in high-precision YUV material.
    The strange part is that if I bring the AE animations into AE and try to apply an effect in AE and re-render out, the re-render (using identical codec) ALSO has this sort of pull-down / repetition of frames. Anyone know what is going on? It drives me crazy because I can’t adjust anything that I bring out of AE into FCP, like color correct or crop.
    Jeremy Garchow replied 15 years, 1 month ago 2 Members · 4 Replies
  • Jeremy Garchow
    August 6, 2011 at 2:43 pm
    Mak sure you set your frame rate to 23.976 not 23.98 in AE and rerender.
    Makes a huge difference.
  • Alan Langdon
    August 6, 2011 at 9:17 pm
    A-ha. I suspected this. Why didn’t I try this then? I will, now. Thanks a bunch, I’ll get back and let you know if it worked.
  • Alan Langdon
    August 6, 2011 at 10:36 pm
    Hm… Strange. I thought I was possibly renderig in 23,976 but actually all comps in AE are 23,98 fps, as well as the Final Cut timeline… What could be going on here?
  • Jeremy Garchow
    August 7, 2011 at 12:17 am
    Your AE comps should be 23.976
    FCP shorthands this to 23.98, but it’s really 23.976 “under the hood”.
    Jeremy
