Activity Forums Apple Final Cut Pro Legacy ProRes Question
  • ProRes Question
    Posted by Scott Sutter on July 8, 2007 at 1:31 pm
    Just got final cut studio 2 friday and after imaging my drive and installing the software, it seemed to work without a hitch. I have a few questions though, maybe i read the fine print wrong or whatever but isnt pro-res supposed to be an easy setup for capturing? I am running a dual 3ghz mac pro with 5gb of ram, a kona 3 card, and a 2.4 tb external sata raid 5+0. I started toying around with the new final cut and noticed a lot of nice new things and a lot of the same things. Whats the proper way to setup for capturing HD from an f-500 hd deck or an m-2000 hd deck and bring it in pro-res HQ in the system? Ive always just used the kona 3 easy setup for uncompressed 8bit 29.97 and had no problems, but i want to try out the pro res codec to see what it looks like and im not sure how to setup my easy setup. Any help would be greatly appreciated. Thanks
    Tom Wolsky replied 19 years, 2 months ago 4 Members · 8 Replies
  • 8 Replies
  • John Pale
    July 8, 2007 at 2:58 pm
    If you don’t see ProRes Easy Setups, then you have not updated your Kona drivers for FCS 2.0.
    Go to AJA’s website and download.
  • Tom Wolsky
    July 8, 2007 at 3:08 pm
    I believe ProRes capture is only available on Intel machines with hardware support.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • John Pale
    July 8, 2007 at 4:01 pm
    He has a MacPro, Tom…so he can do it.
    The Easy Setups show up, even on non-qualified Kona equipped machines (such as mine), useless as they are.
  • Walter Biscardi
    July 8, 2007 at 4:34 pm
    [Tom Wolsky]
    I believe ProRes capture is only available on Intel machines with hardware support.”
    Not anymore. FCP 6.0.1 now allows our G5 Quad to capture ProRes all day long.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Scott Sutter
    July 8, 2007 at 5:09 pm
    hmmm..im gonna have to check it out once i am back in the office monday. It seemed kind of weird that after i installed it that i didint see any of those easy setups. Any other ideas?
  • Walter Biscardi
    July 8, 2007 at 5:17 pm
    [scotts1919] “It seemed kind of weird that after i installed it that i didint see any of those easy setups. Any other ideas?”
    Installed what? FCP 6 or the Kona 4.0 drivers for FCP 6? If you did not install the new Kona drivers, you will not see any sort of ProRes easy setups.
  • Scott Sutter
    July 8, 2007 at 6:05 pm
    i installed the fcp 6. i thought that i had installed the new kona drivers a few weeks ago but im not sure. I am going to check tomorrow at the office. thanks for the info guys!
  • Tom Wolsky
    July 8, 2007 at 6:52 pm
    Sorry. Misread. Thought he had a G5.
    All the best,
    Tom
