Activity › Forums › Adobe Premiere Pro › ProRes Proxy to HQ reconnect glitchy
  • ProRes Proxy to HQ reconnect glitchy
    Posted by Nate Matson on March 4, 2013 at 5:38 pm
    Hello,
    I searched “The Cow” to no avail, so here goes.
    My problem:
    I shot a music video using DSLRs. I ingested the files to FCP 7 as both ProRes (Proxy) and ProResHQ.
    I edited my footage using proxy. Everything went great. I’ve done this many times.
    When I reconnected to my ProResHQ files, I started to get slight glitchy lines that look like tape hits, or some sort of digital distortion. I reconnected for a second time, and got the same issue… The source H.264 files do not have these glitches, nor do the proxy files.
    I double-checked my sequence settings and they are the same.
    I sent the sequence to Color, and the files are glitchy in the same spots. I did a generic grade to see if that made any difference – and it did! when I looked at the graded sequence in FCP 7 the glitches were worse!
    Any ideas what might be causing this? Any Ideas about how to remedy this?
    All the best,
    Nate
    Nate Matson replied 13 years, 6 months ago 2 Members · 2 Replies
