Activity Forums Apple Final Cut Pro Legacy ProRes “Print to Tape”?
  • John Pale
    July 6, 2007 at 7:02 pm
    FCP 6 can output a DV signal via Firewire from a timeline that is not DV.
    Can also do this from an HD sequence if your system is fast enough.
  • John Pale
    July 6, 2007 at 7:03 pm
    To be clear, what is traveling out the Firewire is NOT Pro Res…its transcoding to DV NTSC on the fly.
  • Jerry Hofmann
    July 6, 2007 at 8:17 pm
    I doubt there will be a wit of problems…
    Jerry
