Activity › Forums › AJA Video Systems › ProRes on Kona2?
  • John Ladle
    June 6, 2007 at 5:10 pm
    Per the apple tech article, you need an Intel MacPro to capture prores 422 HD.
    because the Kona 2 operates in only PCI-x bus slots and those systems operate only in dual G5 2.7 or less…um, no. maybe a chance in hell it can downconvert and capture to SD, you will know soon enough when you test it.
  • Walter Biscardi
    June 6, 2007 at 5:57 pm
    [pixeleyed] “Anyone out there with a Kona2 having success with ProRes? I vaguely over-read addition of ProRes to Kona3, is that true for Kona2 too?”
    No because a Kona 2 only runs on the PowerPC G5’s and those don’t support Pro Res capture. I’m pretty sure you can capture to a native codec and then edit in a ProRes timeline, but we have not tried that out here so I can’t say for certain.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • John Ladle
    June 6, 2007 at 9:17 pm
    [walter biscardi] “No because a Kona 2 only runs on the PowerPC G5’s and those don’t support Pro Res capture”
    just a quick clarification–G5’s support HD PRO RES 422. now the SD world of ProRes capture off of signal is not yet defined. The Quad G5 will certainly chug through it. (have your Activity Monitor CPU Usage window up and watch it redline!)
    but in all reality, i dont believe based on some tests i did that the PCI-X bus systems will do much.
  • David Battistella
    June 6, 2007 at 10:26 pm
    I’ve already captured Pro res in SD through the AJA i/o box. I think this is an Apple ploy to get us all to move up to INtel Mac’s
    David
    Peace and Love 🙂
    Read my Blog
    https://blogs.creativecow.net/DavidBattistella
  • Francois Driessen
    June 7, 2007 at 1:19 am
    OK. I guess it’s time then. Sorry, my baby-G and Kona2. It’s not just with AfterEffects CS3, now FCP too. You served me well… (This is an emotional moment for me).
    I guess I will be even more emotional when the 8-core arrives at my door. + the bill for all the memory to make it sing with AE!
