Activity › Forums › Blackmagic Design › ProRes NTSC – 8-bit or 10-bit???
  • ProRes NTSC – 8-bit or 10-bit???
    Posted by Sean Oneil on May 30, 2007 at 8:46 pm
    I noticed the Easy Setup for Blackmagic ProRes NTSC is 8-bit, not 10-bit.
    I changed the digitizer to 10-bit and my test file size was identical to when it was 8-bit.
    Is ProRes recording 8 or 10 bit? I thought you could pick either or.
    Kristian Lam replied 19 years, 4 months ago 3 Members · 4 Replies
  • Sean Oneil
    May 30, 2007 at 8:54 pm
    I just did some reading in the documentation. It appears ProRes is a 10-bit codec.
    So it appears you guys made a mistake when creating the Easy Setup for NTSC.
  • Sean Oneil
    May 30, 2007 at 9:06 pm
    What the hell? I just noticed that all the ProRes Easy Setups, including HD, are all 8-bit. Surely that can’t be right.
  • Kaspar Kallas
    May 31, 2007 at 11:25 am
    Yeah – what is up with that!?
    -Kaspar
  • Kristian Lam
    June 1, 2007 at 1:52 am
    My error when creating the easy setups. I’ve corrected this so if you need it, email me at support[at]blackmagic-design.com
    regards
    Kristian Lam
    Blackmagic Design
