Activity › Forums › Apple Final Cut Pro Legacy › ProRes not in Capture Preset
Posted by Tobias Schrenk on January 20, 2009 at 11:09 pmHello,
I just installed Final Cut on my new MacPro and wanted to change in my Caputre Preset to ProRes. Now I searched through the list and could not find the preset. Is this normal ? Do I have to install something else before I can use it ?
Thanks a lot for any help
Andrew Kimery replied 17 years, 8 months ago 3 Members · 6 Replies -
Shane Ross
January 20, 2009 at 11:13 pmWhat version of FCP did you install?
Shane
Shane
Read my blog, Little Frog in High Def -
Shane Ross
January 20, 2009 at 11:42 pmAnd you looked in the Easy Setups in the HD options and you don’t see Apple ProRes?
Shane
Tobias Schrenk
January 20, 2009 at 11:50 pmYeah excatly. I looked it up in the Easy Setup and wanted to change it. But no ProRes there…..
Shane Ross
January 21, 2009 at 12:01 amReinstall FCP. On top of what you have…that will add the missing codec.
Shane
Andrew Kimery
January 21, 2009 at 6:59 amDo you have an I/O card installed (like a Kona or Blackmagic)? Are you trying to capture HDV as ProRes via FW? I work w/multiple FCP machines (all 6.0.4) and the only ones that have ProRes presets are the ones with I/O cards installed. All the others just have a single ProRes preset called HDV-Apple ProRes 422 1080p24. AFAIK if you want to capture HDV as ProRes via FW you have to make a custom setting. This article from KenStone.com should help.
https://www.kenstone.net/fcp_homepage/capture_hdv_prores_fw_balis.html
-A
