Activity › Forums › Adobe Premiere Pro › Prores looks bloggy in Premiere Pro
  • Prores looks bloggy in Premiere Pro
    Posted by Tapio Haaja on August 5, 2011 at 10:28 am
    I’ve been testing different codecs with Premiere and although Prores works nicely for some reason in source/program monitor Prores files looks little pixelated. And yes I’ve full resolution turned on etc.. It seems that prores files are scaled to screen with nearest neighbour (or worse) algorithm instead of bilinear/bicubic. I’ve Macpro 10.6.7 and latest codecs that came with Final Cut Pro X installed. Actually I noticed that also some other Quicktimes look bad such as Uncompressed 8-bit. Quicktime IMX looks great but has wrong gamma…
    Best
    Tapio Haaja
    On-Air Promotion Producer
    https://avseikkailuja.blogspot.com/
    Jeff Brown replied 15 years, 1 month ago 2 Members · 1 Reply
  • Jeff Brown
    August 5, 2011 at 3:30 pm
    Is it possible that the QuickTime files do not have the “use high quality” flag checked in the movie properites? (accessable via QT Pro)
    just wondering, I edit on a PC.
    -jeff
