Activity Forums Apple Final Cut Pro Legacy ProRes keeps making me render audio?
  • ProRes keeps making me render audio?
    Posted by John Whiteway on May 17, 2012 at 9:43 pm
    Hello,
    The other day I used Compressor to change some MP4 video files from a Blackberry Playbook tablet to ProRes so that I could edit them in Final Cut. I opened Final cut and without altering my existing Audio/Video settings imported the files. When I did I got a message asking me if I wanted the settings in my new sequence to conform to those of my media source. I clicked yes. After that all works fine up to a point. I can watch and listen to the clips in the Viewer but once I make a selection and place it in the Timeline I get the little red line that says I have to render the audio. I do that and all’s fine again. But this is a nuisance, and somehow I feel this shouldn’t be the case. I’ve opened a new Project and Sequence and changed all the settings to the ones you see below, then imported the same files. But no change.
    Does anyone understand what’s happening and how I might correct things?
    John
    Here are my A/V Settings as they are now:
    Sequence Preset: Apple ProRes (HQ) 1280 X 720 30p 48 kHz
    Capture Preset” HDV- Apple ProRes (HQ)…. (I didn’t think the Playbook was HDV but there is only one ProRes (HQ) setting to choose from. Also this shouldn’t matter as the files were converted in Compressor and directly imported.)
    Device Control: Firewire NTSC
    Video Playback: [missing] Apple Firewire NTSC (720X 480)
    Audio Playback: default
    Bret Williams replied 14 years, 4 months ago 4 Members · 13 Replies
  • 13 Replies
  • Shane Ross
    May 17, 2012 at 10:26 pm
    You no doubt had AUDIO PASSTHROUGH selected when you did the conversion. It’s on by default. You need to uncheck that and manually make the audio Linear PCM 16bit stereo 48kHz. Otherwise FCP will want to render.
    Shane
    Little Frog Post
  • Jerry Wise
    May 17, 2012 at 10:40 pm
    i also would get the red line and i found out that my sequence was set to 48khz but my source was 44.1khz. i ran it thru soundtrack pro and upped it to 48 and all was good.
  • John Whiteway
    May 18, 2012 at 3:22 pm
    Thank you very much for the reply. This is the first time I’ve used Compressor so am still sorting my way through the program. I’ve gone back to look at the settings I’ve used and see that, as you say, AUDIO PASSTHROUGH is the default setting with the ProRes 422 (HQ) codec. I’m wondering though where I’d go to change that to Linear PCM 16bit stereo 48kHz as you suggest. In the Inspector pane I can click on an icon that would seem to offer me the chance to change audio settings but these options are all greyed out, as if with the choice of ProRes you are stuck with the entire package. Is there some other place in the program where I can make this manual change? Or do I have to be using something other than ProRes (HQ) to begin with? (Also while I’m at it, I’m assuming that correcting my problem means changing these settings then converting my Playbook MP4 files all over again.)
    Again, thanks very much for taking the time to give me your help.
    John
  • John Whiteway
    May 18, 2012 at 4:04 pm
    Thanks very much for the reply.
    Right now I’m going to try the solution suggested by Shane Ross. I think it will work, but I’m kind of restricted to doing that anyway. Seems this challenge of converting MP4 files has thrown me into a study of FC Studio I’ve been able to avoid till now. In short, I’ve never had reason to tackle Compressor or Soundtrack Pro before, and so far it’s just been Compressor I’ve been doing battle with. Soundtrack Pro is next on my plate, so as it is right now I wouldn’t know how to make the conversions you outline above.
    I did, out of curiosity, go back over some of the notes I’ve accumulated in the last few days. I went onto Blackberry chat rooms, and there one fellow replied giving me the full specs on the MP4 files the Playbook produces. He says it’s audio is “MPEG-4 AAC at 128Kbps, stereo (2 channels) 48 kHz sampling” If that is the case do you think the solution you suggest would work in my case? (If I strike out on Shane’s idea I will be tackling Soundtrack Pro and your suggestion next.)
    Thanks again for all your help.
    John
  • Bret Williams
    May 18, 2012 at 4:58 pm
    You sure don’t need prores HQ! Use 422 or LT.
  • John Whiteway
    May 18, 2012 at 5:44 pm
    Thanks for the reply.
    I’m wondering if either 422 or LT would help.
    At the moment I’m trying to figure out how I can apply Shane’s suggested solution of removing “audio passthrough” and manually setting the audio. Trouble I’m facing is that all the QuickTime codex, including the two you’ve just mentioned, include “audio passthrough”. And if one goes to Inspector is seems that none of these codex allow a change in audio setting. (As the manual says, I’ve just found out, “If a setting has “pass-through” selected the Filter pane audio filters are not available…”)
    Bottom line I’m wondering if any QuickTime codex can solve my problem.
    John
  • John Whiteway
    May 18, 2012 at 7:11 pm
    I’ve just been searching Compressor to see if I can figure out how to do what you suggest. I can highlite the ProRes codex I used in the settings window but when I do that I can’t figure out where this button is that will allow me to create a custom preset. It’s likely in front of my nose, but could you tell me exactly where it is?
    Thanks.
    John
  • Shane Ross
    May 18, 2012 at 7:14 pm
    IN the INSPECTOR…the ENCODER tab, second from the left. VIDEO will say ENABLED, and AUDIO will have the “settings” greyed out and say PASS-THROUGH. CLick on PASS-THRU and choose ENABLED. Then click on SETTINGS.
    Shane
    Little Frog Post
  • John Whiteway
    May 18, 2012 at 7:44 pm
    Hi.
    Wish I could attach a screen-shot of the information I’m seeing on Inspector/Encoder.
    As you say, to the right of “Video” is a button saying “Settings”. To the right of that is another button saying “Enabled”. Directly below the word “Video” is the word “Audio” and next to it buttons that say “Settings” and “Pass-through”.
    The problem is the entire Inspector/Encoder window is greyed out and will not allow me to make any of the changes you suggest.
    John
  • John Whiteway
    May 18, 2012 at 8:16 pm
    Sorry for being so slow with all of this.
    My problem seems to be two-fold. 1) When ProRes 422 (HQ) is highlighted I can not see the button you suggest I hit to create a custom preset. 2)When ProRes 422 (HQ) is highlighted the Inspector/Encoder window allows no changes.
    I’m at a loss.
    John
