Activity Forums Adobe Premiere Pro Prores in Premiere Pro CS5 on PC
  • Prores in Premiere Pro CS5 on PC
    Posted by Jimmy Doyle on May 17, 2011 at 6:52 pm
    I edit mostly in Premiere Pro CS5 but also use Final Cut Pro when I have to. I use Premiere Pro on a PC and Final Cut on a Hackintosh I built myself.
    I will be editing an upcoming project that will be shot on an HPX 170 and recorded into an AJA Ki Pro Mini in Prores 4:2:2. I prefer to use Premiere Pro, by a huge margin. Will I be able to import the Prores footage directly from compact flash cards? If not, can I import from the compact flash cards into a mac and transfer to PC with external hard drives?
    Kevin Monahan replied 15 years, 4 months ago 3 Members · 3 Replies
  • Mike Tomei
    May 17, 2011 at 7:46 pm
    Hello Jimmy,
    You will be able to read ProRes files on your PC, but not write ProRes files. You could look to using DNxHD (Avid’s codec, which is a free download from their site) or the Cineform codec (which isn’t free). Both of those read and write well using Premiere on a PC.
    If you want to import ProRes files, edit them, then export to a ProRes file, you’ll have to stick with Final Cut or Premiere Pro on a Mac.
    Mike Tomei
    Intel i7-930 2.8GHz
    12 GB RAM
    1 GB VRAM
    500GB system HD, 4x1TB RAID5 media array
    Adobe Production Premium CS5
    https://blog.miketomei.com
  • Jimmy Doyle
    May 17, 2011 at 7:54 pm
    Thanks for the quick response!
    I do not need to export as Prores. Can I edit the Prores footage in Premiere Pro CS5 on a PC or will it first have to be converted to something else first? And what would I use to convert it?
  • Kevin Monahan
    May 17, 2011 at 10:53 pm
    You can edit in ProRes, no conversion needed as long as you have QuickTime installed.
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
