Prores HQ files render to Prores Proxy in multicam
Hello,
I’m currently working on a 6 camera multicam edit of a concert I shot a few weeks ago. I converted all of my h.264 files to Prores Proxy for the edit, and then reconnected the proxies with ProresHQ files to do a minor color grade. All the files reconnected correctly, but when I rendered out my sequence all the files seem to look like my proxy files. When I check the item settings for each file it says they are ProresHQ.
I exported a sequence at current settings and it gave me a proxy quicktime file. I did another export but manually switched the settings to ProresHQ and the files looked great.
I’m not sure what I’m doing wrong at the render stage.
All my RT settings are set to playback at High Quality and Full Frame Rate.
Anyone experience this before?
