Activity Forums Apple Final Cut Pro Legacy ProRes HQ bitrate.
  • ProRes HQ bitrate.
    Posted by Ayman Abdel-basset on October 27, 2009 at 8:47 am
    Hi
    i dealed with captured material full HD prores HQ..
    when i checked its data bitrate it was 186 mbit/sec..
    when i exported it using the QT convertion dialuge..and then viewed the settings of the output mov file..
    i found it prores HQ but its data rate became smaller 146 mbit/sec..
    there is no settings i can change in the export dialouge so why the bit rate dropped like this??
    Best regards
    |A|
    Ayman Abdel-basset replied 16 years, 10 months ago 3 Members · 3 Replies
  • Rafael Amador
    October 27, 2009 at 9:09 am
    Hi Ayman,
    This is why people avoid using QT Conversion.
    No control. No idea what’s going on inside.
    Export QT Movie with current settings.
    rafael
    http://www.nagavideo.com
  • Neil Sadwelkar
    October 27, 2009 at 12:13 pm
    Going through the bit rates for various codecs in Apple’s ProRes whitepaper, I find that 184 mbps is the data rate for 1080p25 or 1080i50.
    Mind that ProRes are variable rate codecs, so the given data rate is the maximum. Depending on the complexity of the scene, actual data rate may be lower as well. QT Player shows actual data rate for that movie.
    So, for instance if you place a colour bar for 10 sec in a ProResHQ 1080p25 timeline and export it as a QT movie it is only 20MB is size with a bitrate of 16mpbs.
    If, instead you place a video clip, that same 10 sec becomes 215 MB with a data rate of over 180 mbps.
    To take this further if you place a still jpg in the same timeline for 10 sec and export it as a QT, that QT is 202 MB at 169 mbps.
    Give that still a gentle DVE move and export, now its the same image, but in motion. And that QT is 187 MB at 157 mbps.
    So, 10 sec of ProResHQ shows such widely varying data rates depending on image content.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Ayman Abdel-basset
    October 27, 2009 at 3:30 pm
    i did..using quick time export without any change..
    it became lower data rate..
    the original was 186 mbps
    the new shot (same as original)became 181 mbps .
    |A|
    Ayman Abdel-Basset
    https://www.mbasset.com
    Abu-Dhabi UAE
