Activity › Forums › Apple Final Cut Pro Legacy › ProRes HQ 24fps + Other Formats in Same Sequence
Posted by Kevin Monahan on October 23, 2009 at 7:03 pmGuys,
Doing additional editing, effects and consulting on a feature that show ProRes HQ at true 24 fps (not 23.98).There are some pick up shots that must be inserted, however, all are XDCAM 25 fps, 24 fps and 23.98 fps. I don’t see a problem with the 24 fps footage, but should I be converting the other two formats before outputting, or should I just render them out and let them be? Doesn’t appear to be any visual difference on my client monitor with the different formats.
Cheers for anyone that’s been down this road.
Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut ProKevin Monahan replied 16 years, 10 months ago 5 Members · 10 Replies -
Arnie Schlissel
October 23, 2009 at 8:08 pmI don’t see a problem using Cinema Tools to conform the 23.98 to 24. You can get away with that for the 25, as well.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Kevin Monahan
October 23, 2009 at 9:10 pmThanks for the idea Arnie.
Kevin Monahan
Author – Motion Graphics and Effects in Final Cut Pro -
Michael Gissing
October 23, 2009 at 9:30 pm[Arnie Schlissel] “You can get away with that for the 25, as well.”
Will that slow it down 4% altering audio pitch? That might be a problem, although pitch can be corrected.
Gary Adcock
October 23, 2009 at 9:38 pm[Kevin Monahan] “There are some pick up shots that must be inserted, however, all are XDCAM 25 fps, 24 fps and 23.98 fps. I don’t see a problem with the 24 fps footage, but should I be converting the other two formats before outputting”
Hey Kev.
try doing a conform to 24.0 of all the media in CinemaTools, I find that unless it is all material of the same subject- most do not see close enough to realize that the content has been speeded up or slowed down unless it is a direct cut in the middle of the action.
a simple dip to color dissolve allows the eye to refresh and more easily accept the new frame rate.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, ILhttps://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Kevin Monahan
October 23, 2009 at 10:05 pmIf I conformed everything to 24.0, what are the ramifications for sync sound?
Kevin Monahan
Gary Adcock
October 24, 2009 at 12:26 am[Kevin Monahan] “If I conformed everything to 24.0, what are the ramifications for sync sound? “
it will pitch shift. I have been known to recut the original audio back in using the natural pauses in speech to re-sync if needed, since you said it was not a lot, this might be an option.
The 3-4% change is well within the voice compression guidelines used to get more said in a commercials, or you could pitch shift in Adobe Sound booth (not sure how the new version of STP handles adjusting pitch)
gary adcock
Studio37
Kevin Monahan
October 24, 2009 at 5:54 amThank you Gary. These are nice tidbits of wisdom, and make total sense.
I am having a little trouble conforming my footage in Cinema Tools. It doesn’t seem to be able to reconform the XDCAM clips. Can anyone confirm that XDCAM 25fps cannot be conformed to 24.0fps in CT?
My colleagues on the film really appreciate your help guys. The Cow Rocks!
Info about the film: https://www.imdb.com/title/tt1039613/
The film features Academy Award Nominee Klaus Maria Brandauer, a giant of teutonic cinema.Kevin Monahan
Michael Gissing
October 24, 2009 at 6:16 am25 – 24 is 4%. best software for pitch conversion in my experience is Pitch N Time or MPEX3.
The new Sound Track Pro has pitch tools which are worth trying on sync & dialog. They may be good enough but I would suggest keeping the original as well so the sound post people can make a choice.
Neil Sadwelkar
October 24, 2009 at 9:22 amYou cannot use CT to conform XDCam clips from 25 to 24. That’s because they are MPEG. You can, however convert them to ProRes and then conform them. That works.
You can batch compress a bunch of clips to ProRes with Compressor.
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India -
Kevin Monahan
October 24, 2009 at 4:57 pmThanks a bunch Neil. I’ll pass this along.
Kevin Monahan
