Activity › Forums › Panasonic Cameras › ProRes from AVCDH as Multi-clip in FCP
  • ProRes from AVCDH as Multi-clip in FCP
    Posted by Daniel Schultz on February 11, 2010 at 2:07 pm
    Hi Noah,
    I was wondering if you might be able to help out with this. I asked the question in the FCP forum, but haven’t gotten an answer. I did a 2-cam shoot with the HMC150 and a Canon. I wasn’t able to edit the two as a multi-clip in FCP 6.0.6. So I tried converting the Canon footage to prores in Compressor, as advised by someone in the FCP forum. That didn’t work either…got the message the the clips’ CODECs don’t match. I posted that in the FCP forum and was told that FCP does not support proRes for Multi-clip.
    Is this the case? And if not, do you know a workaround to be able to get both of these cam’s clips working as a multi-clip on the timeline?
    Thanks again,
    Dan S.
    Roberto a Zavala replied 16 years, 7 months ago 3 Members · 6 Replies
