Activity Forums Apple Final Cut Pro Legacy .prores Files
  • Posted by Phil Evans on November 23, 2011 at 12:45 pm
    Hello all
    I have been sent some rushes and amongst the .movs are also .prores, .pcm and xml files. I was just wondering how I could have a look at the .prores files – I can’t seem to open them in QT or FCP.
    Any help would be much appreciated
    Phil
    Phil Evans replied 12 years, 3 months ago 3 Members · 5 Replies
  • Chris Tompkins
    November 23, 2011 at 5:17 pm
    Prores is native to apple. If you can’t bring them into FCP, then something is really wrong with them.
    What happens when you just double click the file @ the finder level?
    Chris Tompkins
    Video Atlanta LLC
  • Phil Evans
    November 23, 2011 at 9:34 pm
    Hi Chris
    The files are actually .prores files, ie “filename.prores”. The Mac sees it as a UNIX file, as it does when it doesn’t recognise the file type. It seems that its the output from broadcast system with the audio and video as separate streams, not in a .mov container, if you see what I mean. I’m trying to get in contact with the guy who sent it to me but just wondered if there was a simple solution.
  • Kristel Ottis
    June 25, 2014 at 3:21 pm
    Did you ever figure out how to handle these files? I’m dealing with the same issue.
  • Phil Evans
    June 25, 2014 at 3:23 pm
    Sorry, don’t remember if I found a solution for this or not.
  • Chris Tompkins
    June 25, 2014 at 3:32 pm
    .prores for a file extension is new to me. Prores is the codec. They should be .MOV files.
    What did your files from?
    Chris
