Activity › Forums › Adobe Premiere Pro › ProRes files offline
  • ProRes files offline
    Posted by Steve Brame on October 7, 2014 at 7:38 pm
    Updated to 2014.1 this morning, and just opened a project that had a mix of media, including some ProRes files from a BlackMagic Pocket Cinema Camera. All of the ProRes files are now offline, and when I attempt to relink, I get – “The importer reported a generic error.”
    I tried to relink to a couple of the files on my backup drive, and those relink. So, I’m copying the backup versions over to the RAID.
    I tried creating a new project, and the ‘offline’ ProRes files import with no problem, so it’s not an issue of all of the files mysteriously going corrupt.
    Apparently, something corrupted in that project, and since it happened immediately after the 2014.1 update, I’m inclined to suspect that.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
    Chris Borjis replied 11 years, 11 months ago 4 Members · 11 Replies
  • 11 Replies
  • Steve Brame
    October 7, 2014 at 7:56 pm
    OK, just located another offline file, not a ProRes file, but a stock MOV encoded to QT. So that made me wonder if it’s an ‘Adobe QT32 Server.exe’ problem. Sure enough, ‘Adobe QT32 Server.exe’ isn’t running when I start open that project, but when I start a new project and import some ProRes files, ‘Adobe QT32 Server.exe’ starts.
    Steve Brame
  • Steve Brame
    October 7, 2014 at 9:32 pm
    I can relink the clips to the files on the backup drive, but when I copy the backup versions over to my RAID, they cannot be relinked or imported into this project. The can be imported into a new project, though.
    Steve Brame
  • Steve Brame
    October 8, 2014 at 1:35 pm
    “Chat is unavailable right now.”
    Sigh…
    Steve Brame
  • Kevin Monahan
    October 8, 2014 at 5:08 pm
    Sorry about that Steve. I’ll look into the issue, sorry you’re having trouble.
    In general, I would not update any projects without backing that project up with a duplicate (that way, you can always open the project in the original version). Our agents report that there is sometimes unexpected behavior like this when customers update project files.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Steve Brame
    October 8, 2014 at 5:56 pm
    Luckily, 2014.1 comes with native Cineform encoding, so I was able to transcode the files to that, and then link those files with the offline clips, so I’m working again.
    Still, it needs to be noted. Since both of the codecs involved are QT Server specific, I’d think something went haywire with that process. However, it seems that I am the only one suffering the issue…again.
    Steve Brame
  • Kevin Monahan
    October 8, 2014 at 9:39 pm
    Actually, you’re not. I see a few people with QT based clips going off line. I’m investigating.
    Kevin
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
  • Chris Borjis
    October 13, 2014 at 4:31 pm
    any luck?
    having the same issue.
  • Ken Jones
    October 13, 2014 at 8:40 pm
    I’m having a very similar issue. When I try to import a ProRes file into a project I get the spinning beach ball and have to force quit Premiere. I have not run the latest updates yet. I am running v.8.0.1
  • Chris Borjis
    October 14, 2014 at 3:38 pm
    I tried updating itunes as someone in another thread suggested
    as well as updating the pro apps codecs (shown in os x updates)
    still showing pro res files offline.
  • Chris Borjis
    October 14, 2014 at 4:35 pm
    Read on another thread that renaming the prores file then reconnecting
    media seems to work and it does…but that would be painful on a huge project.
    I just changed a dash in the file name to an underscore and also deleted the cache file associated
    right next to it.
    Then it worked.
    Kevin, where are we at on a fix for this?
    My mac with Kona3G has this problem, but not my mac with Black magic interface, if that helps at all.
