Activity Forums VEGAS Pro ProRes file choking Vegas 9
  • ProRes file choking Vegas 9
    Posted by Tony Derosa-grund on September 12, 2010 at 9:02 pm
    Have a ProRes 422 File from FCP (96G). Can drop it into time line of Vegas no problem. However playback of audio is choppy (audio is fine).
    Any help appreciated.
    Running Vegas 9A and QT 7.6.0
    OS Name Microsoft Windows 7 Ultimate
    Version 6.1.7600 Build 7600
    System Manufacturer HP-Pavilion
    System Model NC747AAR-ABA a6763w
    System Type x64-based PC
    Processor AMD Phenom(tm) 9150e Quad-Core Processor, 1800 Mhz, 4 Core(s), 4 Logical Processor(s)
    Installed Physical Memory (RAM) 7.00 GB
    Total Physical Memory 6.87 GB
    Available Physical Memory 3.68 GB
    Total Virtual Memory 13.7 GB
    Available Virtual Memory 10.0 GB
    Page File Space 6.87 GB
    Page File C:\pagefile.sys
    Phil Seymour replied 16 years ago 4 Members · 8 Replies
  • 8 Replies
  • John Rofrano
    September 12, 2010 at 11:13 pm
    Try updating your Vegas Pro to 9.0e and Quicktime to 7.6.6. Do not install Quicktime 7.6.7 as some have reported problems with it and Vegas.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Tony Derosa-grund
    September 13, 2010 at 1:23 am
    Thanks John. I know you have posted this before but what is the highest version of QT you can use with Vegas 9(a)?
  • John Rofrano
    September 13, 2010 at 10:37 am
    I don’t know because I haven’t use 9.0a in a long, long time and I don’t know why anyone would stay on this release with 4 releases of bug fixes after that. I’m guessing the 7.6.2 should work on 9.0a.
    ~jr
  • Tony Derosa-grund
    September 13, 2010 at 1:16 pm
    I knwo Vegas can handle a ProRes 422 but can it handle Pro Res LT, Proxy and HQ equally as well?
    Also what high quality/ HD format do you prefer coming out of FCP that works best on Vegas w/o loss?
  • John Rofrano
    September 13, 2010 at 9:32 pm
    I believe as long as it’s a form of ProRes you can decode it on the PC. This is an Apple Quicktime limitation and not a limitation of Vegas.
    FCP is extremely limited in the codecs it can use. I think ProRes is the only option other than uncompressed.
    Now if you don’t mind a little loss, I have read that some people are using Sony MXF to go between Vegas and FCP with good success and quality. There is a free Sony MXF plug-in for FCP from Sony.
    ~jr
  • Phil Seymour
    September 14, 2010 at 11:59 am
    John… I might be on the wrong track, bot I am having issues with (I think it is) mov files, and I have qt reader 7.6.7 loaded (Vegas 9e).
    You say to load 7.6.6 but where can I get it now Apple only has 7.6.7 on its site?
  • Mike Kujbida
    September 14, 2010 at 12:35 pm
    Phil, you can find most older versions of QuickTime on the Avid site
  • Phil Seymour
    September 15, 2010 at 7:35 am
    Mike, thanks so much.
