Activity › Forums › Apple Final Cut Pro Legacy › Prores field setting
Posted by Declan Smith on March 18, 2010 at 10:18 amWhen using the prores codec, I notice there is a field option, defaults to Upper. All my footage is progressive. Should I leave this as Upper or should I indeed set it to none ?
Declan Smith
https://www.madpanic.tv
FCS3 / After Effects CS4 / Combustion / Canon 7D / Canon XL2Declan Smith replied 16 years, 6 months ago 2 Members · 6 Replies -
Tom Wolsky
March 18, 2010 at 11:33 amFor a sequence? Set it to none.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Declan Smith
March 18, 2010 at 12:18 pmThanks. And I presume also set it none when transcoding between say h.264 and prores ?
I think my confusion has come from the tool tip in mpeg streamclip.
Declan Smith
FCS3 / After Effects CS4 / Combustion / Canon 7D / Canon XL2 -
Tom Wolsky
March 18, 2010 at 1:58 pm“I presume also set it none when transcoding between say h.264 and prores”
Where does this occur in your workflow?
“I think my confusion has come from the tool tip in mpeg streamclip.”
What tool tip are you talking about?
All the best,
Tom
Declan Smith
March 19, 2010 at 8:36 pmThis is at the start of my workflow. I have obviously made this mistake as I followed the tool tip, which at the time I thought was odd, but as a relative newcomer to Mac / ProRes, I took it at face value.
I have attached a screen shot of MPEG Streamclip, which I use to batch convert canon 7D h.264 files to prores. The Canon EOS 7D plugin for FCP has been released today and in that manual it mentions about setting the field order to none, which makes sense to me.
Declan Smith
Tom Wolsky
March 19, 2010 at 10:43 pmI see what you’re referring to. HD is upper field first. Yes, for your material it should be set to none, through in fact it will not make any difference as the material has no fields to start with.
All the best,
Tom
Declan Smith
March 19, 2010 at 11:26 pmHi Tom
Unfortunately MPEG stream-clip only allows selection of Upper or Lower. I think the main problem I was facing was with the sequence settings, as any motion that I had introduced (such as zooms etc) has what looked like interlaced artifacts appearing, but when set to none, it was fine.
Thanks for you help on this.
Declan Smith
