Activity Forums Apple Final Cut Pro Legacy ProRes Crashes FCP and entire machine…
  • ProRes Crashes FCP and entire machine…
    Posted by Carl Sundermann on November 10, 2008 at 5:56 pm
    Hi all –
    Having a problem using Prores, can’t seem to pinpoint what’s causing
    it. I’m getting a lot of crashing as I render my sequences.
    Workflow –
    Shoot HDV 720p using JVC HD250 cameras.
    Injest from JVC BR-HD50 deck via AJA IoHD (Out HDMI from deck)
    IoHD is set to 720p 59.94.
    Edit, adding lower thirds and other graphics imported from Motion or
    After Effects CS3. (Lower thirds are the Animation codec, and AE
    imports are usually ProRes, unless I need an alpha channel, then I’ll
    use Animation).
    Problem –
    Many times (lets say 3 out of 5) when I’m finished with a sequence,
    and Opt+R to render all, it will start fine, but get to a point and
    the machine will sound like it’s starting a jet engine, and I’ll try
    to move the mouse and it will be locked up. The machine will stay in
    this state until manually shutting off or pulling the cord (I left it
    overnight like this once to see if it would come back, and it did
    not). And unless I make sure to pull the power cord after I’ve shut
    off the machine, when I start it back up, it will have the fans
    roaring again as well. When I do get it back up and running, I’ll
    restart Final Cut and it will have defaulted back to the factory
    window layout, all on one screen. Capture scratch is still set
    appropriately.
    What I’ve tried –
    Rendering smaller sections seems to help the problem. By turning on
    the options to have it render everything when I do Cmd+R, and setting
    in/out points, saving between renders, I’m able to get it rendered.
    However, it STILL DOES crash on occasion when doing it this way (this
    is what finally irritated me enough to write a post to the group
    because it just happened to me a few minutes ago).
    I’ve tried to notice when it crashes, and from what I can tell, it’s
    not at the same part of the sequence each time..
    I’ve tried using FCP Rescue. No difference.
    I’ve tried repairing permissions. No difference.
    I’ve tried turning off spotlight on all but my main HD. No
    difference. (found that on a post on the Cow, I think.)
    I’ve tried leaving the machine to autorender all open sequences.
    Same problem.
    This is not just one project. We’ve been noticing this ever since we
    started working with Prores, and have been trying to find solutions.
    I’ve tried copy/paste to a new sequence. Same problem.
    Machine specs –
    2 x 3 Ghz Quad Core Intel Xeon
    16GB RAM (all the same, purchased at the same time from OWC)
    Four 750GB Hard Drives – Projects, Projects Backup, Media, System
    FCP 6.0.4
    OSX 10.5.5
    While rendering, viewing the Activity Monitor, I can see all 8 cores
    are running approx 70-80%
    The kicker is that we have two machines configured just as above, and
    they BOTH experience this behavior on rendering.
    Has anyone noticed anything like this? Are there other things I can
    do to check in the system? (Like permissions?)
    I am mixing different formats in the timeline, so I don’t know that
    Prores is totally to blame (ie, Animation codec for lower thirds,
    Prores for the rest of the video, TIFF images for stills, DV content
    from old SD footage).
    Whatever the problem is, it makes this workflow VERY difficult to use!
    TIA-
    Carl Sundermann
    Carl Sundermann replied 17 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
