Activity Forums Compression Techniques ProRes Compression loses quality on some colors more than others?
  • ProRes Compression loses quality on some colors more than others?
    Posted by Eddie Gali on March 12, 2012 at 7:28 pm
    Hey Folks,
    So I rendered a movie out of AE with Apple ProRes 422 and Apple ProRes 422 (HQ).
    I then exported the file using H.264 with a MPEG-4 wrapper using MPEG Streamclip 1.9.2. It’s a slide show and most of the images have the word “SPORT” in them in large block letters in varying colors and backgrounds. Now you can see that when the movie is rendered with ProRes that the area around the word “SPORT” in one of the still images becomes slightly blurred around the edges, which when compressed into H.264 becomes pixelated. “SPORT” is Magenta-Red (R:207, G:6, B:127) on a Deep Magenta-Red (R:84, G:1, B:37) background. None of the other colors become blurred in the render or pixelated after compression. I’m assuming the problem is with the initial rendering. The settings are listed below. My boss says he’s heard that certain colors aren’t compressed as well and told me to look into it.
    Render Settings
    Quality: Best
    Resolution: Full
    Proxy Use: Use No Proxies,
    Effects: Current Settings
    Disk Cache: Read Only
    Color Depth: Current Settings
    Frame Blending: On for Checked Layers
    Field Render: Off
    Pulldown: Off
    Motion Blur: On for Checked Layers
    Use OpenGL: Off
    Solos: Current Settings
    Output Module
    Format: QuickTime
    Output Info: Apple ProRes 422
    Spatial Quality = 100
    Output Audio: 48.000 kHz / 16 bit/ Stereo
    Channels: RGB
    Depth: Millions of Colors
    Color: Premultiplied
    Final Size: 1280×720
    Any insight is appreciated. Thanks!
    Eddie Gali replied 14 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
