Activity Forums Apple Final Cut Pro Legacy ProRes codec for editing stills?
  • ProRes codec for editing stills?
    Posted by Mickey Power on November 15, 2007 at 4:11 am
    Howdy
    Which codec is best to edit together in FCP series of high res stills for screening in a photographic exhibition? The images will screen off a 1024 x 768 projector. The final program will probably come out of a mini mac using Eudora then out to projector.
    The images are high resolution and naturally I want to maximise quality. I’ve read here that DVC PRO HD is one way to go. Another is Apple ProRes, understanding they would have to be downconverted before screening. If ProRes, what settings in Easy Setup do I use?
    Thanks very much.
    Mickey
    Mickey Power replied 18 years, 9 months ago 2 Members · 2 Replies
  • Arnie Schlissel
    November 15, 2007 at 5:28 am
    I would do this in Motion, not FCP. You can set up a custom timeline setting to match the projector, and make your final export in Photo-JPEG codec. Of course, your realtime preview out from Motion will be a bit slower that way. If you want to add Music, you can add that in Motion, QT Pro, or even in FCP.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Mickey Power
    November 15, 2007 at 5:35 am
    Thanks, I’d given that thought. But the question remains, what codec do you choose to maintain highest quality possible?
    Mickey
