Activity Forums Adobe Premiere Pro ProRes Bug
  • ProRes Bug
    Posted by Gerry Curtis on November 8, 2012 at 11:59 pm
    Hello There,
    A received a motion graphic with a transparent alpha channel in ProRes 4444. However Premiere 6.0.2 doesn’t read the transparency, it shows as black. Ignore alpha is unchecked under interpret footage.
    I’m one of the main editors doing freelance work for a prominent foundation that the editors should switch from Final Cut to Premiere, but when issues like this occur it makes them think Premiere isn’t ready for prime time.
    The transparency works fine in Final Cut Pro, my workaround was to convert the graphic to Animation which creates an extremely large file and is inconvenient for me.
    I’m working with a Mac Pro, Quadro 4000, Lion.
    Any help would be appreciated.
    Gerry
    http://www.digitalkilnstudios.com
    http://www.savasanafilm.com
    Gerry Curtis replied 13 years, 10 months ago 1 Member · 1 Reply
