Activity › Forums › AJA Video Systems › ProRes = bad render with Slomo
  • ProRes = bad render with Slomo
    Posted by Bill Portune on October 24, 2009 at 5:20 pm
    I have a sequence of shots in a ProRes timeline that are at 75% speed (or any speed change). When I render any transitions or title supers I get flashing at the bottom of the frame. It seems to include the last 5 or so lines and has a 4 frame cycle. I’ve tried dropping the same shots in various timelines (DV, DV50) and the problem is still there – seems it’s associated with the source material not the timeline settings. I even re-digitized new source material with the same results. I was able to use a crop of 1 at the bottom of each shot which solved the problem.
    Anyone else able to recreate the issue?
    Using a MacPro 8 core, FCP 7.0.1, Snow Leopard, AJA iOHD 7.1
    Bill Portune replied 16 years, 11 months ago 1 Member · 1 Reply
  • Bill Portune
    October 24, 2009 at 6:23 pm
    – 525 29.97 ProRes
    – Was happening before I went to snow leopard with FCP 7.0
