Activity Forums Apple Final Cut Pro Legacy ProRes Audio Sync
  • ProRes Audio Sync
    Posted by Kevin Matluk on August 3, 2009 at 3:48 pm
    Everything I import as Apple ProRes seems to be 6 frames out of sync, when taken into FCP. The footage, imported as HDTV 1080i, 29.97, 48.000kHz 24-bit, looks fine outside of FCP in Raw form, but when brought into FCP, the sync is off. Pulling a clip into a new sequence and matching the sequence with the clip settings still has audio which I have to push forward 6frames. I created some test sequences as 60FPS, and 59.94FPS seem to be in Sync, but when I export (As any format in those sequences), the video is very fast and jumpy. 29.97FPS is the only sequence setting that works and matches the clip settings, but audio is off.
    Kevin Matluk replied 17 years, 1 month ago 2 Members · 2 Replies
  • David Roth weiss
    August 3, 2009 at 4:10 pm
    Actually that would most likely be four frames, and it’s fixed by changing the Frame Offset from the default of 4 to 0 as you see below in the Playback tab of your System Settings.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Kevin Matluk
    August 3, 2009 at 4:30 pm
    Hmm, I would have never thought of that! Thanks a bunch David
