Activity Forums Apple Final Cut Pro Legacy ProRes and a ref monitor
  • ProRes and a ref monitor
    Posted by Jay Wolf on February 17, 2008 at 6:10 pm
    I have the Matrox MXO and have transcoded HDV to ProRes to work with Color.
    But now I don’t have a setting for ProRes under Video Playback…?!
    The ProRes footage looks a lot more reddish than the original HDV material.
    Am I overlooking something very simple or…
    is Color going to upgrade ProRes to Uncompressed (8bit) and should I chose that setting?
    G5 Quad, 3.5 Gig RAM, OS 10.4.10, FCS 2
    Sean Oneil replied 18 years, 7 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    February 17, 2008 at 6:27 pm
    ProRes can’t be monitored externally directly… that’s why you don’t see a video playback option for it… the MXO will play it back though, just choose HD matching the frame size you’re working with in the ProRes sequence.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Sean Oneil
    February 17, 2008 at 10:16 pm
    [Jerry Hofmann] “ProRes can’t be monitored externally directly”
    That’s not a very accurate characterization. Video codecs can never be “monitored directly” without first being decoded to uncompressed video.
    The only reason you would ever see a ProRes video playback option is if you are sending the compressed stream over firewire to an external decoder, like the AJA IOHD – in which case the IO is converting it to uncompressed video. But it does not monitor ProRes directly, as you put it.
    Sorry for the snobby technical correction. But I can imagine numerous people mis-interpreting what you said as some sort of deficiency with the MXO and/or ProRes in general – which is not the case.
    Sean
