Activity Forums Avid Media Composer ProRes 854×486 SD import (4:3 anamorphic)
  • ProRes 854×486 SD import (4:3 anamorphic)
    Posted by Hugue Loiselle on May 24, 2013 at 12:24 am
    Just had a clip to import in Avid 4.5
    ProRes HQ 854X486 (4:3 anamorphic)
    Works well in SD but at export with the same settings, i’m loosing quality.
    Should I work and export in HD or Work and export in SD?
    Its not a ratio Problem
    How should I import the clip?
    Don’t know if the problem is at import or export.
    Thank you
    Hugue
    Hugue
    Ricky Barrow replied 13 years, 4 months ago 2 Members · 1 Reply
  • Ricky Barrow
    May 24, 2013 at 12:53 pm
    The final intended destination might help you decide workflow. With the file being 16×9, I would bring it into HD project and export 16×9 rather than be confined by anamorphic … especially if this is for web/computer use so it can be progressive vs. interlaced …. I might add that I prefer to do this even if for DVD, at which point you have the option to make the DVD progressive or interlace.
    Ricky
