Activity Forums Compression Techniques ProRes 720×486 Black Lines
  • ProRes 720×486 Black Lines
    Posted by John Michaels on December 7, 2015 at 6:23 pm
    Hello, hoping for a sanity check here.
    I’m taking a lot of 1080p 23.976 HD masters and center cutting them down to 720×486 23.976 SD ProRes files (just following orders). When I do this, I get black lines at the top and bottom of the frame.
    Now, my understanding is that these black lines should be there; it’s the VBI, correct? My files keep getting rejected by the powers that be, because of those black lines. However, the client is also explicitly asking for 486 and not 480 so I can’t just go that route.
    I did notice that if I bring the files in to Final Cut Pro or view them in Quicktime 7, that the black bars remain, instead of being somehow “hidden” as would happen with another SD format such as IMX50. Is it possible this is just a metadata issue of some sort?
    Attached is a frame grab, and below is a mediainfo readout of the file:
    General
    Complete name : /Users/JohnMichaels/Desktop/test.mov
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 53.2 GiB
    Duration : 2h 6mn
    Overall bit rate mode : Variable
    Overall bit rate : 60.2 Mbps
    Encoded date : UTC 2015-11-23 17:45:58
    Tagged date : UTC 2015-11-23 17:45:58
    Video
    Format : ProRes
    Format version : Version 0
    Format profile : 422 HQ
    Codec ID : apch
    Duration : 2h 6mn
    Bit rate mode : Variable
    Bit rate : 48.6 Mbps
    Width : 720 pixels
    Clean aperture width : 720 pixels
    Height : 486 pixels
    Clean aperture height : 486 pixels
    Display aspect ratio : 4:3
    Clean aperture display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:2
    Scan type : Progressive
    Bits/(Pixel*Frame) : 5.798
    Stream size : 43.0 GiB (81%)
    Title : Telestream Inc. Telestream Media Framework - Release TXGP 2015.12.176624
    Writing library : apt0
    Color primaries : BT.601 NTSC
    Transfer characteristics : BT.709
    Matrix coefficients : BT.601
    matrix_coefficients_Original : BT.601
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Unsigned
    Codec ID : in24
    Duration : 2h 6mn
    Bit rate mode : Constant
    Bit rate : 11.5 Mbps
    Channel(s) : 10 channels
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Stream size : 10.2 GiB (19%)
    Language : English
    Other
    Type : Time code
    Format : QuickTime TC
    Duration : 2h 6mn
    Time code of first frame : 00:57:30:00
    Time code, striped : Yes
    Language : English
    Bit rate mode : CBR
    Craig Seeman replied 10 years, 9 months ago 2 Members · 3 Replies
  • Craig Seeman
    December 7, 2015 at 7:18 pm
    Quicktime 7 Player (and Frameworks) are deprecated.
    Please test in Telestream Switch 2.0.1 and Quicktime X.
    Please explain exactly what your settings are in the Resize Filter (be complete).
    What version of Episode are you using (current is version 7).
    Also please do describe intended use of the encoded file.
  • John Michaels
    December 7, 2015 at 7:22 pm
    Same thing in Switch an Quicktime X.
    I’m doing this in Vantage (not Episode) using the Quicktime (Telestream) encoder. For my Resize filter, I’ve tried both “Crop (Center Cut)” and Manual, with 0 crop and padding on top and bottom, and 240 pixel crop in from left and right. Both resize settings yield the same result. I do have the VBI settings enabled (which is the default) for 4 upper and 2 lower. I’m sure disabling this (setting it to full frame active picture) would get rid of the bars, but again, aren’t they supposed to be there for 486 material?
  • Craig Seeman
    December 8, 2015 at 5:00 am
    [John Michaels] “I’m sure disabling this (setting it to full frame active picture) would get rid of the bars, but again, aren’t they supposed to be there for 486 material?”
    I think you should get rid of the bars especially if that’s what they want. As to the 6 lines, HD to SD conversion can involve going to 720×480 source and one would need to add the lines (4 on top, 2 bottom as you mention) to get a 486 standard for broadcast. Those lines wouldn’t be visible due to TV overscan.That wouldn’t be VBI though. It its not for broadcast it can be left at 720×480 (DVD for example).
    This is why I wonder what the intent is. Might there be a next stage where someone will add pull down frames and interlace? If it’s for DVD use 720×480 would be fine. In fact one might do 720×480 anamorphic for SD 16×9 to keep the aspect ratio.
    VBI would be 720×512. This is how I would deliver SD broadcast spots back in the day to DGFastchannel for distribution.
