ProRes 720p – Flash
Hi All,
I have recently upgraded and made the push to HD with a purchase of the HMC-150. To save space and because our website does not have the capability to playback HD quite yet I have been shooting in 720P.
The end result is SD 16×9 Flash.
My strategy thus far has been work in HD with HD graphics (lower thirds and a right hand corner branding bug). From there I send the project right to compressor and use DV NTSC anamorphic. I then take that format and use On2 Flix Standard and set it to use source framerate and frame size. 96 kbps audio and a maximum bitrate of 700kbps – to try and gain a little extra quality over the preset 512 kbps.
For the most part I feel this looks alright but I feel like the graphics are getting mangled in the flash conversion. They look fine to me in quicktime (though I believe I’m running quicktime X for what it’s worth). The graphics on the web look more like when you preview a file in Finder by hitting the spacebar.
My two questions then are – Is there a better way to get to Flash from FCP
Should I compress down to SD and then put the graphics in?Your time, answers, and any other suggestions are greatly appreciated
