Activity Forums AJA Video Systems ProRes 4444XQ playback
  • ProRes 4444XQ playback
    Posted by Frederico Cengarle on June 6, 2016 at 4:31 pm
    HI,
    I’m currently trying to playback some ProRes 444XQ UHD material through my Kona 3G card and seem to have a bit of difficulty. The playback drop a lot of frames and is not playing in realtime. I ran the AJA test tool to check both harddrive and system speed and looking at the result, I seem to have sufficent speed to playback the file but still, I cannot seem able to do it.
    Now The MacPro I use is kinda old (early 2009) so I was wondering if the issue can come from there? And if so, does anyone know the minimum sys requirement to be able to play UHD ProRes material?
    Thanks a lot.
    Fred
    Frederico Cengarle replied 10 years, 3 months ago 2 Members · 4 Replies
  • Warren Eig
    June 7, 2016 at 3:56 pm
    Have you tried playing it back with AJA’s Control Room™ utility?
    Warren Eig
    O 310-470-0905
    email: info@babyboompictures.com
    website: https://www.BabyBoomPictures.com
    For Camera Accessories – Monitors and Batteries
    website: https://www.EigRig.com
  • Frederico Cengarle
    June 8, 2016 at 12:23 pm
    Hi Warren,
    thanks for the reply. Yup, I did try to play it in AJA’s control room, but I got a lot of drop frames during playback. What is weird is that I also ran AJA’s test system and the number that I got shows that I seem to have enough speed (both on HardDrive and System) to run the file.
    Fred
  • Warren Eig
    June 8, 2016 at 3:49 pm
    First, never run media on the system drive. What kind of RAID are you using? You need a sustained transfer speed not just a single fast drive. The speed test may be showing you a burst of speed, but it has to be a sustained speed, hence a RAID.
    Warren Eig
    O 310-470-0905
    June 8, 2016 at 4:03 pm
    Hi Warren,
    sorry for the confusion, I wasn’t quite clear on my last reply. When I said “System” I meant that I run a check “System” (hardware, card and everything). The files reside on a big SAN (Stornext from Quantum)
    Fred
